A small update, got the bosche 044 fuel pump on, so added to the walbro 255 that gives me a serious 55lph punch of fuel! No more fuel issue, so as long as i run my ice bath, i should be sneaking into the 10's this week!
ALMOST THERE!!!!! you got it the nxt couple times out for sure! best of luck to you brother!!!
1991 blue L, 5 speed.
1988 red L-plus-all stock.
I wish, the frame on this thing is beefy! its about as light as its gonna get. The last thing i did was put skinnies on it, and that almost completely offset the weight of the turbo setup....
Well went back to the track last night, still disappointed. I got some 275 wide drags, but didn't have time to put them on my rims, sooo, with the 235's on again, she went .05 seconds faster at 11.24@131mph. This was on about 13lbs. My computer died on me so I couldn't log the run. Tune is good, I short shifted 1st so it wouldn't blow the tires off, spun just a tad going into second, but I will be forever limited until I upgrade my Tranny.....
Slip
I'm digging the 1/8th mph, was hoping to see more of a gain on the back end. I think it's time to go back to my 3.23's(3.70's currently)
with a 6 speed, your already in fifth with the 70's arent you? maybe sixth at 130(not familiar with high HP LS cars)
Ha ha, No my car is a manual valve bodied auto... it's just a 700r4, I really need to upgrade the tranny, I just dont have the money right now. For reference, My buddy ran 10.86@126mph last night in his third gen camaro with an LS Turbo, and I trapped 131.99 on my last run, So when I do get a good tranny, as the car sits I should be running down around 10.20-10.40.
Ok, update since last time. A couple days ago I purchased a whole set of MKIV rims, 17X8 in front, and 17X9.5 in the rear. They aren't on right now, but look pretty good!!
I ran the car today, it was 90+ degrees at the track. Once again did slightly better. Same 2.0 60', which will never change on this setup....
Car went 11.16@132.5mph. I need to throw my 3.23's back in the rear, as I was hitting the rev limiter crossing the finish line(6800rpm)
Here are the slips for the day. This was peaking 15lbs but holding 14lbs. Also hit 104.6mph in the eighth!
