Daniel's TruckStiva Build Thread (56k warning)
  • I got one commin its the one with like a pigtail built onto it
    1991 stiva.
    • got the steering wheel painted to match the rest of the blue, interior is almost done just need to make door panels.
      1991 stiva.
      • Re: Daniel's TruckStiva Build Thread (56k warning)
        Awesome man, that car is beautiful.
        • well... 52 pages of awesomeness...
          • Got a bit more done today. Got my hids installed. And working. Worked on my rear brakes got them mounted and working and painted. Installed a battery and hold down.
            1991 stiva.
            • I'm sure somebody has already asked, but I'm not about to search through 50+pages to find the answer....
              Where did you get the gull wings?
              BTW:
              The car is looking sexy as hell!!!!!
              • Originally posted by Flw Sock View Post
                BTW:
                I made them from scratch, then decided to take them off and now the doors open like normal. just shaved handles. .... couldn't get past the idea of how hard it would be to get fuel, or park in a crowded lot. ......... if you look through the 50 pages you will find yourself addicted lol.
                thanks for the compliments
                1991 stiva.
                  The Ranger lights are freaking awesome! They look bland on the truck, but set these cars OFF!
                  • Originally posted by daniel_cogar View Post
                    I actually did start at 1 last night, and go until about 25 before I went to bed lol
                    • got all new brake lines ran today and bleed them, rock solid brakes now. also mounted my under body light kit. just waiting on flywheel bolts to come in, then I can install the engine, trans, drive shaft. got a radiator, fuel cell, and floor mats on the way. also installed a new 70A alternator and belt.
                      1991 stiva.
                      • vw's getting jealous so i had to take a pic
                        1991 stiva.
                        • I love how ratty that VW is starting to look with time... LOL
                          • Originally posted by Christ View Post
                            yeah its always been a car I wanted and my next bigger project is a subaru engine swap into it.
                            1991 stiva.
                            • got a few little things done today, rear shock mounts installed and bolted down. installed new wiper motor and adjusted wiper blades, bolted down column plastic and installed quick release hub and steering wheel. mounted horn and wired it up. wired up my third brake light in my rear wing. Also painted my ignition coil bracket, and bolted up the coil. I'm slowly making progress and more and more I'm thinking about turbocharging it on min boost untill I can afford a MS. Id be using a bp ecu, gtx injectors which i think are 330cc, and I have a td05 14b and a Holset hx35w. still learning about turbo stuff. Let me know what ya think would be the best way to go.
                              1991 stiva.
                              • I wouldn't bother boosting on NA stuff. It'll never seem *right* and too easy to blow it up due to improper fueling.
                                I have a SAFC2 piggyback if you're interested at all... but it'll take a chunk out of your MS budget.
                                91GL BP/F3A with boost
