JeMartin's Festy Build Thread
  • JeMartin's Festy Build Thread
    So, this is the build thread for my Festiva. Here I'll document my Festiva's hopeful transformation into a decent autocross vehicle.
    My first Festy. 1990 L PLUS. 5 speed. 54,000 miles. New radiator. Pretty decently rust free considering it's lived its life in the rust belt and around here the roads are usually whiter from salt than they are from snow.
    It has been in some fendor benders in its life. The rear corner was dented in and the previous owner drilled some holes and pulled it out, so I'll have to deal with that.
    The front looks good from the outside, but underneath its a bit bent up. I think i can get it close to how its should be without too much trouble.
    I've been hanging around on fordfestiva.com for a while now, but I finally found myself one. I've always really liked Festivas. I think I was mainly influenced by a friend of my family's having a fully ITD prepped racecar festiva. I figured now is the time to get this project started. I've wanted a manual car to work on my manual driving and Festys are cheap, relatively sporty, and good on MPG(as opposed to my '11 Tacoma).
    Goal:
    Transform it into primarily a SOLO car. Aiming for some modified class in the future(I need to do a little more research before I pick one). Want it to still be streetable enough to drive around.
    List:
    General Maitanance
    change oil/filter ------------------done
    check/change other fluids --------done
    kn air filter (#33-2222)-----------done
    change fuel filters
    Replace brake consumables -------done
    Clean
    clean interior
    clean engine/engine bay ----------in progress
    Replace side mirrors
    Replaced PS with delete trim ------done
    Replace L tailight --------------------------done
    Fix Rust spots
    Fix rear dent
    Remove rear seat (class: mod)
    Strip entire interior (class: mod)
    Fix front end damage
    ~Remove side trim pieces
    ~Replace front/rear bumper covers with painted ones.
    ~Repaint to ?white
    Coilovers:
    KYB GR2 front --------------------have
    KYB rear -------------------------have
    Ground Control coilover kit --------have
    AutoXing wheels and tires
    Probably some 13" steelies(AEROs, diamond, etc...)
    A number of slick options for 13" wheels
    Rear Spoiler (looks cool and it probably adds a few HP)
    Fuel cell
    Relocate battery
    marine box --------------------have
    Lighter battery
    (Braille, etc...)
    Bucket seat
    Roll Cage
    5/6 point harness
    Clutch (look into classing implications)
    High Flow Muffler
    Slotted rotors
    Front Strut Bar
    Rear Strut Bar
    Stiffer Engine Mounts
    Stiffer Suspension bushings
    sway bar/LCA bushings
    sway bar/chassis bushings
    rear beam bushings
    Aspire Swap:
    Aspire brake swap (look into classing implications)
    Aspire Front Suspension (look into classing implications)
    Aspire Rear Suspension (look into classing implications)
    Aspire front roll bar
    I'll add pictures when I can get my photobucket to work again...
    looks like your gonna have a great build there ....congrats on the festy an im looking forward to seeing this project come along
    Don't meddle in the affairs of Dragons for you are crunchy an taste great with katsup!!!
