Figured it was time to update the thread. Hopefully, I'll be able to close this thing out shortly. A lot has happened, but most of it I have already posted in different threads. So, to bring this thread current and complete;
First: Someone stole the front wheels and tires from the car......still have no leads and their probably gone forever. The factory 12" wheels will go back on the car until I can figure out what direction I want to go.
Second: I made a custom gauge panel from a piece of an old dash bezel. Turned out real nice....looks even better in the car!
Third: The new B6 is installed. The swap came out looking like a factory option. There were a couple very simple issues with the swap, most centered around the larger B6 intake manifold, but nothing that the average guy with hand tools couldn't fix. All in all, it was truely a "bolt-in". I did spend a small amount of money on new Stainless button head cap screws for the valve cover and various brackets.
Fourth: I fired it up last week and ran it for 20 minutes @ 2500RPM to break in the cam. The engine started first round and ran like a top. Throttle response was awsome.....oil pressure, not so much, LOL. 40Lbs @ cold start, 20Lbs @ 2500RPM (hot) and only 3-5Lbs @ hot idle. I'm 99.99% sure the problem is a leak between the case and cover on the oil pump. I have a new pump shipping from Rock Auto ($66) and I should get it installed later this week. You can also see that the clear coat on the exhaust manifold shield tunred a slightly gold color above the #1 exhaust port. I'm guessing that cylinder #1 is a little lean....possibly a partly clogged or weak injector. I'm not concerned at this point. As soon as I get the oil pressure figured out and get the thing on the road, I'll address the tuning issues.
