Originally posted by Nerd Racing
Quest for More Power and More Traction! BP+T + AWD Build Thread
^^ Yup.
Got some more work done today, got the final rear floor panel cut out and in place. I just need to weld it in, but I have to figure how to hold it in place better first.
Hopefully welding it in Tomorrow after work!89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Looking good! Keep the updates coming I wanna see this thing doing some suby drifts yo!!!1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
My protege drifts way better than a subaru
40-60 torque split is way better for kicking the rear end out
should be the same bias on this setup as I'm using protege/gtx stuff.
Facebook Me!
Sweet!!! I wasn't sure how they were split thanks for the info!!! I'd love to feel a little launch in your car, some suby's are nuts!!1992 white L, Bp, American racing 13's, stock trans.
Well in order to keep my trans alive I rarely launch. If I can locate another (they come up from time to time) I'll try a couple at the track.
Welded on a piece of angle to add a little more rigidity to the floor pan:
I will be screwing the rear floor piece to it so it will be held in place while I weld it in. Eventually this will all get a seal to keep the moisture out, but have the sub frame removable still.
Also... Apparently clamping with a c-clamp that was made in china is too much to ask...
I was tightening it and it decided to break in half...89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
your just too powerful bro.. just too powerful!2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I had my wheaties that morning must be!
Today's progress... Drilled me some holes and slapped in some bolts!
Well partially. I didn't want to punch through the bottom just yet. I'll save that for tomorrow I think.
I gotta figure out how I'm going to drill these holes...
I'm thinking shorter bit and a right angle drill attachment...
I have a hole saw I am going to use so that I can put my pipe bushing between the unibody so it doesn't crush upon tightening.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Can you get to it from the bottom? use a punch to mark the center and drill it from the bottom?? lol ..i dunno, you'll figure it out i'm sure..
looks like you made a nice platform for your speaker box to sit on!2008 Kia Rio- new beater
I mounted the subframe with existing smaller bolts, then drilled up & worked from there:
Did you use locating dowels to positively register alignment with the chassis?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
not yet Man, This is just the sub frame I made, the precise alignment will take place when I mount the miata crossmember to the sub frame. Once I get it in place I'm torquing it down and drill pinning it at all 4 corners to keep it from moving.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Picked up this right angle attachment for $18 and it did the trick with a small drill bit so I could get all the way through.
Then I went up from the bottom with the larger bit.
6 bolts through the sub frame and the unibody!
I think my bolts might be a touch too long...
I'll probably just lop them off or turn them down in my lathe. Still deciding if I want to use what I have or go back to grade 8 hex head bolts... maybe button head fasteners? decisions decisions...
I added some more sheet metal to the sub frame so it would seal up well enough on the sides too.
That's probably it till Friday. I need to take a day off and do some laundry and clean up around the apartment tomorrow.
On another note... I had a slip waiting for me in the mailbox, I have to pick up my seat covers at the post office tomorrow on lunch.
Can't wait, I gotta get the AWD swap done just so I can use the seat covers!
Facebook Me!
Hookay so I got these in the mail today!
Is it wrong that I am more excited about installing and using them than I am the AWD BPT setup??
I have a GTR intake and throttle body on the way as well.89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Sweet
I like updates lol
