Update: new nankang tires installed. Interior pressure washed, cleared about 20lbs of built up gravel dust. New struts in the mail coming soon.
NTRCOOL's build/ repair thread
here are some before pics of what was hiding under the carpet and panels:eeeeeek:NTRCOOL
1993 Ford Festiva GL
1990 ASC/McLaren Turbo Grand Prix x2
1989 ASC/McLaren Turbo Grand Prix
1990 Cadillac Fleet-wood Brougham
1987 Buick LeSabere T-Type
1980 Oldsmobile Ninety Eight Regency coupe
1977 Chevrolet Caprice Classic Aeroback coupe
Here are the after shots it was crazy how much dirt was hiding in this car I think I picked up on some mpg cleaning all of it out. I still need to take pics of the carpet it almost looks new compared to what it did look like.NTRCOOL
it got pretty clean on the inside then I took it to Jefferson swap meet and got the outside all muddy.
NTRCOOL
Windows are all tinted waterpump is swapped out and I installed my HHO generator finally.NTRCOOL
i see structural rot!!!! not good, nor is the large hole in the left rear strut tower (see previous pictures). that needs to be properly repaired ASAP.Originally posted by NTRCOOL View PostHere are the after shots it was crazy how much dirt was hiding in this car I think I picked up on some mpg cleaning all of it out. I still need to take pics of the carpet it almost looks new compared to what it did look like.Trees aren't kind to me...
here are a few pics of the windows done. the back was a pain in my butt and wasn't my best quality even after fighting it over an hour and yeah I'm far from being a pro.Last edited by NTRCOOL; 05-06-2012, 06:32 PM.NTRCOOL
The KYBs came in after 2 months waiting I got them all installed and it rides sooooooooooo much better!NTRCOOL
HHO generator
Awsome !! I am curious about the HHO gene.Originally posted by NTRCOOL View PostWindows are all tinted waterpump is swapped out and I installed my HHO generator finally.
I have a '89 and would like to install a HHO gene. I am a little nervious.
Where did you get yours, or did you make it. What about the ox sensor?
Just make one, they are simple and easy. They use about a quart of water an hour if
set up properly. You need a reservoir big enough for your needs, you do have to add
water. If you use electrolyte you do not have to worry about freezing. You should install gauges and breakers for safety. You should keep the stored volume of HHO to a minimum, again for safety. It is real easy to accumulate the equivalent of a stick
of dynamite. That can be a lot of fun...when planned!!!Reflex paint by Langeman...Lifted...Tow Rig
Yea I built my own HHO Generator I haven't yet been able to calculate any gains due to my rusted out gas tank. I will eventually replace it. As far as I was able to calculate so far I am getting around 43mpg plus I have to install a pulse width modulator because of how much hydrogen is produced after the plates warm up.NTRCOOL
Yes, if you have a hot mix anything over 15 amps per gallon of generator area will
simply boil the water. I use a reservoir to cool the water in the generator and to
recapture any water being pushed by the hho.
been throwing around ideas like using tuning forks with a matching pizo for plates
or using a ignition coil on each plate with a controllable pulse modulator tied into
engine load.
When too much hho is sent to the engine at low power demands the exhaust starts
sounding like it has firecrackers in it.Reflex paint by Langeman...Lifted...Tow Rig
