The 07095 is the kit number, hd= heavy duty pressure plate, and the last digits are the disk designation.
Cheapest shipping for any of them is 46$, and they can cryo treat them for an extra 40$, which I didn't opt for. I think stage 2 is a full face kevlar disk? It's only rated 15 more HP and costs 50$ more.
I was bored the other night and looked up all the major clutch companies I could think of and jotted down a list of all the stage 1-5 kits, the corresponding part numbers for the pressure plate and friction disk for proteges and 626's, what they were rated for and prices of everything. I didn't make a game of finding the cheapest prices, basically I just used the manufacturers websites. Almost all the companies use the same pressure plate, and the disk is what gives it more or less tq rating. This was the best I could see after shipping and everything was included. If it holds 250 tq as advertised I won't have a problem because I'm only hoping for 200 HP at the wheels/230chp +/-.
I also cross referenced the part numbers on rockauto.com for all the pressure plates/disks/t/o bearings for xr2 capri's, hydro proteges, and 626's (all year 93) and they sell the same components for each car with a g series. So, with any luck, I will be able to use the throwout bearing I got with the 626 kit. It's got toyo stamped on it, and there was a no name pilot bearing too, but I already punched in a national/Moog pilot bearing. Both have "202" stamped on them.
Did you try the EGT half shaft? I think that be a better choice... jus a thought. The Aspire & EGT LH axles's a pretty much the same lenght.So that would put the RH sides very close as well....Peace-
