^^or just get a smaller belt so it clears the frame rail
My last engine swap build thread, FANTASTIVA
Originally posted by Damkid View Post^^or just get a smaller belt so it clears the frame rail
Thats part of plan B. Somehow Ive got to get the belt on the pulley before I mount the alt. No room to slip it on after its mounted. Crazy !sigpic
I remember when I did my BP swap I had plenty of room for the alt..... My guess is that it's just how you have it mounted, have you thought about modifying your mounts to tilt the engine more forward to give more alt clearance?
Originally posted by freshtiva View PostThats part of plan B. Somehow Ive got to get the belt on the pulley before I mount the alt. No room to slip it on after its mounted. Crazy !The Festiva Store
I have to undo the passenger mount and lift up some-Greg
Redneck Engineer
FOTY - '09
Originally posted by BigElCat View Post2) Wheels studs are sweet. There's nothing like tossing a light weight wheel/tire combo on there, have it stay, and center itself. Studs are cheap and it takes about 20 minutes for the conversion when the hubs and drums are off the car.
Got these in the mail today
Should I put some lock tite on them or just crank them down. I cant get to much cranking power with an hex wrench.
Lower alt bolt access
Originally posted by Damkid View Posthave you thought about modifying your mounts to tilt the engine more forward to give more alt clearance?
Originally posted by nonamekid View PostMine is the same way. I take the water pump pulley off to change my belt.
Originally posted by KingFish View PostTake a large pick hook, put the belt across the c/p and alt, using the hook to leverage the belt onto the w/p, then bump the starter. Does that make sense?sigpic
Well that was the single hardest mechanical task I've ever performed. That was a nightmare but its on and I have maybe 3/16" clearance all around. I hope that belt lasts a looooong time. I think I could even tighten it at least one time. Id rather change a timing belt then do that again.
Originally posted by freshtiva View PostThanks buddy !!! Where you been ???Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by freshtiva View PostWell that was the single hardest mechanical task I've ever performed. That was a nightmare but its on and I have maybe 3/16" clearance all around. I hope that belt lasts a looooong time. I think I could even tighten it at least one time. Id rather change a timing belt then do that again.Dan
Blue lock-tite on the studs!
Lookin' good.
I'll toss in a pic of my remote oil filter, although I don't know where you'd mount on Fantastiva. I have a hole where my battery used to be.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
Just a thought I had when I saw how close the engine compartment was getting.
In the summer, I run an aluminum heat sink around the filter. In the winter, I use a thermal wrap to help the oil heat up quicker. I realize you have a remote cooler, but a remote filter could be used too, just to make it easier at oil change time (?)
I could start a thread about the Sammy, if anyone is interested.
'92 Geo Metro XFi
'87 Suzuki Samurai
Nice, the Samurai looks like it would be useful around the ranch. Got out my 12"......fan and installed today, perfect fit !! Starting to get things hooked up.
