project doomsdays B6T build
  • project doomsdays B6T build
    Hey everyone well most of you know that I build stuff like no one else hence why my festy look like something out of a kit car mag lol. I can't tell you how many times I've heard " hey dude, what kind of car is that"
    So I finally decided to post on my B6T build is going with some teaser pic ill keep it as updatted as I can on my virgin mobile phone lol
    Just did the intake this week end
    Frankie
    http://www.facebook.com/#!/profile.p...00000110128487
    required mod #1: lower it!!!!
      Nice looking car man, love those mirrors! What did you use to paint the VC and fuel rail? It's different, definately nice, just different from what I've seen.
      2008 Kia Rio- new beater
      1993 Festiva- Fiona, DD
      1997 Aspire- Babyspire, DD
      1994 Aspire - Project Kiazord
      1994 Aspire- Crustyspire, RIP
        I am got a set of raceland coilovers I'm puttin on it thanks
        Frankie
          An I used a translucent iodized red on the fuel rail with a clear
          Frankie
            Hey guys quick update engine is 95% cleaned I may have screwed my self I was cleanin the my block with a prepall type cleaner an I got some on the crank so I squirted it with pb blaster to keep it lubed an now its makin a skweek when I turn it hmm... well here what I still need timing belt, altenator belt at least two exhaust valves, finish my header project.. will see how far I get this week..
            Frankie
              So I got the oil pump on today and the water pump an the mount bar an got the block painted I'm so excited I finally puttin the thing together..
              Frankie
                Looking good man, did the squeeking go away? My oil pump is next in line, after I figure out what to do with these camshafts..
                  Yea it stopped an I still have to replace two exhaust valves that should be fun any advice on takin cams off?
                  Frankie
                    just be careful and unscrew all the caps/bolts in even amounts. make sure you look at the sprockets so you know how they go back on in relation to the cam angle. If that dohc is like the bp dohc, your gonna have fun getting the valves out! I had to make a tool to get thru the lifter bores!
                      Just thought id put it all together for the first time to see how it looked even more excited now that I see it
                      Frankie
                        So I bought new piston rings an connecting rod bearing is it just easy replace or is a PITA to put the CRB in place
                        Frankie
                          Anybody??? Bump
                          Frankie
                            Very precise, unless you've done it by yourself before you should ask someone to help. It's more than take out and put back in.
                            -Donny
                            -1992 Festiva GL
                            B6D/E-series.
                            -1991 GL
                            BP/Broken E-Series. Working on G transmission.
                            -2011 Mazdaspeed3
                              I bought stock ones and I assumed the I could take the old ones off an replace them is that not the case
                              Frankie
