I suppose the mechanical fuel pump will have to go!!!!!
The carb guy, Roger, thought the fuel lines were maybe to small, but he did not know about the fuel pump lobe on the the cam. Somewhere in this thread is how I polished the lobe, to use the mech pump. Measuring the "lift" on the B6 lobe, I did loose some travel, as the lobe is smaller the the B3 lobe. If I remember correctly, the B3 lobe had .267 lift, and the B6 has only .218 lift. That is about 1/16 less lift!
I am going to order a Carter P4070, a rotary vane electric pump, and see if it can keep the fuel bowl full, and the float up where it is supposed to be.
Performance carb kits. com stated NOT to use a mech pump with a Weber carb and insisted on an electric pump, specifcally a Carter 4070!
Carter pumps, are among the best fuel pumps out there.
So here we go, another attempt to solve the riddle of "The Missing".
I was actually thinking that might be the problemo, I just wanted confirmation. :p
