Hmm, well that just sucks then. You've made me rethink making solid lifter rollers now. The plain ones are probably lighter too, and nearly nothing to go wrong with them being totally solid hunks of metal/s.
My n/a super b3 build
Last edited by sketchman; 10-22-2013, 03:49 PM.Any difference that makes no difference is no difference.
Yeah and getting the cam ground to be aggressive is hard cuz the cam is weak and that's why the rollers dug into it... Matt had mine hardened also so that obviously didn't help it. And those rollers aren't built to handle a steep ramp on the cam so I'm kinda thinking that's what caused it, but can't say for sure.
Sent from my LG-LS970 using Tapatalk
I got everything back from Matt, all valves were bent so all new valves, and new cam with the same grind he had on his. Built the head and was putting it altogether but the intake gasket was torn, so ordered one and they never called me so I called and they sent it back....Grrrrr so I just ordered it off of Amazon so it comes straight to me.
Sent from my LG-LS980 using Tapatalk
wow...
Originally posted by drumnerd33 View PostCost is really not that bad considering im going to have a full custom built basically race motor.... so matt is giving really good prices, i am more then happy with the money i spent with him plus you are giving money to another member and helping him progress the buildability of the b3 and getting amazing work.
This is my first read through, so perhaps later in the thread someone will go in that direction...'91 Festiva L/'73 Windsor Carrera Sport custom
(aka "Jazz Bobstad," "The BobWhan," etc.)
Art is the means whereby(a) society advances: Religion is the definition of the parameters of art. Poetry is the actualization of these...
Originally posted by drumnerd33 View PostI got everything back from Matt, all valves were bent so all new valves, and new cam with the same grind he had on his. Built the head and was putting it altogether but the intake gasket was torn, so ordered one and they never called me so I called and they sent it back....Grrrrr so I just ordered it off of Amazon so it comes straight to me.
Sent from my LG-LS980 using Tapatalk90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Is the new cam the same as the one that he originally made for the motor or is it a different profile?Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
This is the first time I have read this thread. It took me a long time to go through it from the beginning until now. Unbelievable patience. You have inspired me to go for the finish line on my build. I still have a few small things left to do before Ohiostiva. All I can say about your build is one word. Amazing. Did you ever install that MSD blaster coil? The reason I am asking is because I have the same one.
I will gain a small amount of hp but I will gain a decent amount of torque and it will broaden my torque band, my old cam was great but it would fall on its face about 5 grand, This new cam has a larger lobe separation so the torque curve is high and flat and will continue climbing after redline
Originally posted by drumnerd33 View PostI will gain a small amount of hp but I will gain a decent amount of torque and it will broaden my torque band, my old cam was great but it would fall on its face about 5 grand, This new cam has a larger lobe separation so the torque curve is high and flat and will continue climbing after redline
