early golfs are a similar weight to mine, i got 4kg/mm front and 3kg/mm rears tho which are softer than the 5 and 4 that normally come with it. the fronts feel soft but rears hard, might be the dampening set to hard tho ill check. pretty sure its just that its so light back there. i can literally lift the rear corner off the ground no probs
havent driven it yet, wishful thinking but maybe tonight!
