I made a little more progress on Pedro over the weekend. The wiring is all wrapped up (pun intended) and I was able to start the final assembly on everything in the engine bay.
The manual N/A capri ECU I got from Rob is in it's new home. The harness is tucked away along the edge of the sound deadener material.
The engine harness goes through the passenger side fender well. The other wire going into the grommet is my wideband 02 sensor wire.
I added an extra clamp on the drivers side. I like my wiring to be supported well. I also wrapped the harness with friction tape where it passes behind the fenders. A lille extra protection.
Since Pedro needed a new master cylinder, I installed a new master cylinder and booster for a 99 miata. 1 port needed to be plugged, but the rest of the miata master cylinder fits just like the festiva one did. The brake lines fit perfectly without any bending required.
In the above picture, you can also see that the crappy fusable link box has been replaced by a Capri fuse box. I also had to move the coolant overflow reservoir back a bit to allow clearance for the Capri airbox. You can see the support bracket I made under the reservoir.
Here are the finished airbox brackets in place.
New K&N filter in the Capri box.
The Capri airbox and intake fit better than they do in a Capri, lol. The filter is easy to remove and there is clearance all around the box.
