Captain Hammer
  • Captain Hammer
    This will likely be the slowest build ever. I'm mainly just trying to make it look and
    run cleaner, but I work Monday through Saturday and don't own a garage, large
    compressor or welder so pretty much Sunday is the only time I ever have to get
    anything fixed as long as it doesn't require those tools.
    The car:
    So, I've actually owned this Festiva for over a year and never considered fixing
    it up. Then I sold my blue one a while back and missed having a nice Festiva...even
    if I never really fixed or drove the blue one much so I decided to see if I could make
    this one any better. Over the past few weeks I've been looking around junkyards,
    ordering small parts online, buying paint and thinking of stuff to fix.
    I plan to get the engine back into nice running shape. No mods, just repairs. New
    seals and gaskets and whatnot. That stuff will come a bit later though. For now
    I'm coming up with ideas and junking up my home office with car stuff.
    Dreams and aspirations:
    Exterior -
    Aspire rear beam?
    Kia Rio struts / knuckles / brakes in front
    Finish painting if it will ever quit raining (Later I will sand the entire car to either primer or bare metal and respray it all)
    Interior:
    Parts I currently have waiting to go on the car:
    Hatch light
    New arm rests
    Newer console
    Newer A/C controls
    12v Plug in hatch
    Escort dome light
    Cargo light in hatch
    Tach cluster with LED's
    Door handles and window cranks
    Cleaner back seat cover on back seats
    Power inverter and stereo in console box
    New weather stripping (where applicable)
    Cup holder mod from Taurus back in and replace bezel with newer one
    Parts I need or things I need to do:
    Fix wiper wobble
    Clean up door vinyls
    Find intermittent wiper switch
    Find a clock that could work and make it fit
    Repaint pillar plastic trim to something other than an almost tan
    Repaint all back plastics with stone paint like William did...his looks nice.
    Simple sound deadening (matting in trunk and ceiling and possibly butyl)
    Find used good condition seats from something else or preferably good Festiva seats
    Heavier duty trunk (not masonite next time, but probably wood to support more weight with no spare tire in there)
    Mechanical -
    Parts I have:
    Cam seal
    Rear main seal
    Front main seal
    Timing belt
    Timing belt idler
    Timing belt tensioner
    Fuel filter
    Spark plugs and wires
    Water pump
    Thermostat
    Thermostat housing
    Coolant temp sensor
    Upper and lower radiator hoses
    New timing belt covers w/ gaskets
    New vent louvers into dash
    Exhaust gaskets
    New motor mounts and trans mount
    Clutch
    Clutch fork
    Pilot bearing
    Throwout bearing
    New CV axles
    Speedo cable
    Front sway bar bushings
    Drum brakes and hardware
    Things to do:
    Coolant flush
    Trans flush
    Install new parts
    Clean engine
    Clean trans
    Clean crossmember...anything with oil on it really
    Clean engine bay and paint white
    I'm sure there's plenty of parts and things to do that I forgot to list here, but
    since I cant edit it later I guess this'll be a good start
    1993 Festiva - White/Black - 5 speed
    ^^^ Clean looking car!
    Dan
      Thanks a lot
      Dont know why it turned out looking decent in that picture, but unfortunately the rest of the
      body didnt follow suit. Whoever owned it before my Dad put some crazy paint on there that is
      borderline un-sandable. Maybe I'll just use aircraft remover haha
        Imron paint? That stuff was like a rock ....
        I noticed no dents in door/fender, that is kinda rare ....
        Dan
          More like this
          Hmmm...never really thought about it. Yeah, I dont think the car has any dents.
            Is that the red car ?
            those wheels look nice.
            '93 Green L - ' Tiva
              Yep
              And they really do, man. I actually get compliments haha
                Its is lookin' good.
                Much better the the red/black sploched paint.
                Let me know when you plan another jy trip.
                I'm looking for some Mazda & Ford parts.
                Where do you go?
                  Thanks, man Yeah, no joke. Wasn't a fan of the black and red.
                  It definitely needs resanded though. Lots of work.
                  Sure thing, man. What kind of stuff are you looking for? And I go to one out
                  in Mulberry.
                    Protege , 323, MX 3 or 6 consoles, RX7 steering wheels, Escort or Tracer window cranks & inside door handles.
                    some small Festy spare parts.
                      I saw a 323 or two in the Bartow junk yard. You need the center console? They may still have them. What year?
                      No RX-7's, no tracers. There are some Escorts. What years?
                      What did you need off of a Festiva? One is stripped inside and the other has a bit of moldy crap from where someone left the window down. Engine stuff is still there though
                        All early '90s Mazdas.
                        Small Festy engine parts, speedo gear, thermo. cover, etc.
                          Oh, nice. Can you find me a picture of what you need? (color, shape?) That way I'll
                          know what you're interested in. Do you care about the condition or will you possibly
                          repaint stuff?
                          I think the thermostat housings are gone for both, but I can check on the speedo gear
                            Next time you plan on going.
                            Give me a few days heads up , I'd like to go.
                              Sadly I can only go after work on weekdays since I work Monday through Saturday
                              and all of the yards are closed on Sunday :/
