Meepersly's 88 festiva build.
  • Meepersly's 88 festiva build.
    Doing a 1.8l sohc swap. I believe it is the b8-me. Came out of a 1992 Mazda protégé.IMG_20151004_173312.jpgIMG_20151004_173301.jpgIMG_20151004_173301.jpg
    Mostly cleaned already. So excited I can't wait to do this.
    88 Ford Festiva LX "Miogi" B8-ME swapped.
    93 Ford Festiva L "Haywire" Rat infested trashcan WIP
    Nice!!! Nice to see another B8 build. a huge power difference over stock
      That engine is supposed to be 125hp right? Keeping that motor stock puts you right alongside the 2015 fiesta st 'hot hatch'-i think they call it- power to weight ratio wise. Pretty sweet any plans to do anything to the motor for more power or your putting it in as is?
        103 HP for the SOHC 16v B8. The twin-cam BP is 127 HP. But still.
          When I get some money put away I do want to put a turbo on it.
            Did you gather your complete wiring harness and ECM . Good luck with your project .
            New build on the way .
              Ok, i just googled 1992 mazda protege specs and edmunds said 125hp. But like you said, still huge. Stock festiva is 27 pounds each hp has to haul around and this would be roughly 16.6. Thats 10 pounds less each hp has to move. 162% better! should be fun when your done. Add a big turbo and boost it up to 128hp and you've doubled the stock power
                Yep, that is the specs for the BP not the B8. BP=125HP, B8=103HP
                Since you aren't going to trust the information on the forum from a knowledgeable member, here is the wiki page which says the same thing that TominMO stated.
                The Festiva Store
                  For some reason I was remembering the BP as 127 HP, but other sources I've looked at do say 125.
                    https://en.wikipedia.org/wiki/Mazda_B_engine
                    What? I was just explaining where i got that number from, not disagreeing with him. Sorry i wasn't more clear. The numbers i was talking about were for 103 hp and i did say add a big turbo to make 128hp...
                    O well, sorry to be confusing.
                      Getting ecm and manifold bits today.
                        If your car is an 88 like you say in post , you will need the complete vehicle harness and chassis harness .
                          Efi converted it has a 92 engine harness in it
                            Awesome ... Go for it . Good luck
                              Nice. So the 1.8 doesn't require a different harness? What do you all have to change or add to get this engine to fit?
