Wow, i thought there would be more to it. I will look at other threads about these swaps. I helped my brother put a newer motor and turbo in his 89 civic and we had to change the entire wiring harness. Spent forever trying to get lights and dash stuff to work, splicing in the different plugs... We never got the brake lights and reverse lights working so we sent it to a shop. They couldnt fix it and ran new wires from the pedals back but it still never worked right. Parkbrake light on the dash would come on whenever you hit the regular brakes and go out when you pulled the handbrake... :p
Had to hack the whole front end apart to fit the t3/t4 turbo. Set the turbo routing up 3 different ways but Never got it working right. I think the t3t4 was too big for a 1.6l civic. That was years of work and i decided i wasn't going to do something similar. This sounds easier though. So I'm tempted again... :p nothing like making more power!
Meepersly's 88 festiva build.
Originally posted by ralph89891 View PostYou'll also need to grind away a piece of medal by the oil pan to make clearence for the passenger side cv axle; if you are using stock trans. You'll also need to move the vaf plug depending on your vaf location. You'll have to drill a new hole for your passenger motor mount.
Originally posted by ryanprins13 View PostNice. So the 1.8 doesn't require a different harness? What do you all have to change or add to get this engine to fit?
I grabbed the injector harness though because it looks the same and the temp sensor is in a different location on that.Last edited by Meepersly; 10-05-2015, 08:00 PM.
Sent from my iPhone using TapatalkLast edited by ryanprins13; 10-05-2015, 07:48 PM.
If your car is an 88 like you say in post , you will need the complete vehicle harness and chassis harness .
Originally posted by nonamekid View PostYep, that is the specs for the BP not the B8. BP=125HP, B8=103HP
Since you aren't going to trust the information on the forum from a knowledgeable member, here is the wiki page which says the same thing that TominMO stated.
https://en.wikipedia.org/wiki/Mazda_B_engine
O well, sorry to be confusing.
For some reason I was remembering the BP as 127 HP, but other sources I've looked at do say 125.
Originally posted by ryanprins13 View PostOk, i just googled 1992 mazda protege specs and edmunds said 125hp. But like you said, still huge. Stock festiva is 27 pounds each hp has to haul around and this would be roughly 16.6. Thats 10 pounds less each hp has to move. 162% better! should be fun when your done. Add a big turbo and boost it up to 128hp and you've doubled the stock power
Originally posted by TominMO View Post103 HP for the SOHC 16v B8. The twin-cam BP is 127 HP. But still.
Did you gather your complete wiring harness and ECM . Good luck with your project .
