Is your intake track in tact with no holes? These cars,won't run without a leak free intake . Also check that the afm door is moving freely and the plug is tight and clean.
Did you test to see if the fuel pump ran ?
Just watched the video and that click is the afm door . So you should be good there.
I would check cam timing if you havent
