I'm building a go kart powered by a B6 engine and aspire 5 speed trans. I got the engine from a friend that did a b8 swap in his festiva.
The front end is from a 99 Saturn sl1. The rear is the front from a festiva
I started building the frame for a 13hp harbor freight engine when I got in half done it weighted almost 200 pounds. I figured that the 13hp wouldn't push it fast enough.
the tubing is mostly 1 ¼ and 1 ½ sch 40 pipe.
Here are some pictures of the progress so far.
This is the first go kart be for I decided to use a festiva engine.
started on the bigger one.
the donor car at the junk yard.
working on the back end.
fitting the engine up.
I tried to eliminate all the unneeded wires in the harness.
The pile on the left is what I don’t need. That took a while.
I don't know for sure about the weight or wheelbase, I'll let him chime in, but I believe the weight should be well under 1000lbs. Maybe like 700-800? Dont quote me on that :p
