pLeAsE uPdAtE yOuR aCcOuNt
1988 323 Station Wagon KLG4 swap
Lmao ya right.... for the low low price of $399/yr...... fk that
Yup I either call it the blue car or the wagonOriginally posted by 1990new View PostWatched your 323 video .... great job you did on the wagon, I know you are proud of her.. does she have a name?
So I recently got a GoPro so I wanted to make a short video with it, it'll be awesome for when I take the wagon to the track
And testing out imgur for hosting pics
One more step finished, custom battery tray
The last mock up before paint
This is just to show the pieces I welded to the car that the tray bolts to
The tray itself
Bolted in place
Once the battery is in, I made this plate to slide into a slot in the front of the tray to lock down the battery
And the finished product, i plan on cleaning up the battery still since it's out in the open like that
Awsome! You always seem to make a KL swap look easy, and we all know it is not!Have owned 9 so far
KL's actually aren't that difficult to be honest once you figure it out lolOriginally posted by m715 View PostAwsome! You always seem to make a KL swap look easy, and we all know it is not!
All it takes is swapping out enough of them...... Right? Nice try being modest!Have owned 9 so far
Time for an update
Finally got a new windshield installed
The coil over suspension on it was very noisy, clunking and squeaking so I decided to switch it out for the set from my old GT
After replacing the suspension and while my focus was on the rear tire, I noticed it looked like the “toe” was wayyy off so after digging deeper into it I think the rear lateral link was from a BG causing the alignment issue because BF lateral links are non-adjustable..... but the BG ones are, these ones are seized completely solid so it’s just time to replace them with new ones
So what better time to freshen up the rear end of this thing
Here’s how it looked when I started
Removal of the subframe
Fresh coat of paint
The new forward lateral links
Even though the new rear lateral links haven’t arrived yet and since they are easy to change with the subframe installed, I decided to re-install everything so the car is mobile again until they do arrive
And after bleeding out the brakes, set it back on all 4 wheels
Can't one of you computer wizards figure out a way to make the photobucket links work again?'88 Festiva LX 5 speed, A/C, Carb, restored $$$ body paint, badly wrecked @ 200k.
'93 Festiva L, 5 speed, Aqua, bought from the original owner,.Zero rust but very nasty otherwise. Awaits the B6T.
'91 Festiva L, 5 speed, bought to drive while putting the B6T in the '93. now B6ME powered.
If you dont have it already, install the google chrome browser. Then install this extensionOriginally posted by Rick the Quick View PostCan't one of you computer wizards figure out a way to make the photobucket links work again?
It can be a bit weird to navigate the site at times, but I'm able to view all the broken pictures with it
