Resurrecting Casper
  • #91
    Originally posted by FestYboy View Post
    I've grown very comfortable with a squat in hard straight braking (more rear bias). I feel that it helps load the rear so it's ready for the turn in, but that's my experience in Scrappy.
    Oh? Do you have really stiff front front struts? What kind of tires? What i have noticed with different kinds of cars-festivas included is that if you have decent tires and actually brake real hard the rears will lock up because all the weight transfers to the front. Your getting the rear to squat down?
    • #92
      Originally posted by Advancedynamix View Post
      Knowing you, you'll improve upon them. We've got to meet up at a track day soon. How far are you from Chuckwalla? I have been wanting to hit up that little track in Riverside too. There's always Fontana and Willow too. Or you could swing on over here for some cheap track days.
      I've got to get the car setup first. I decided to postpone the engine swap and just run the B3 relocated for now. It's maiden voyage will be Laguna Seca Feb. 20th.
      Those tracks are 6.5-8.5 hours away. It's not out of the question, just going to need some careful planning. It will definitely happen sometime this year.
      91 Festiva BP Autocross/Track/Rallycross hopeful
      14 C7 Z51
      • #93
        FMS springs, kyb struts, dual rear springs, and xr2 front brakes. The whole brake system was rebuilt, and the drums were adjusted as tight as possible so that they applied before the front. This was mainly for pedal feel as I like a high pedal engagement. The tires are 185/60-14 x 6 +35. As it is, when I jump on the brakes, the whole car sits down. Can't explain why, but I like it.
        • #94
          I've had problems with oversteer. Eliminating the rear brakes allows me to brake later and harder without the rear end coming out. My fastest laps in both Pedro and Tweak have been with the rear brakes disabled.
          I have had the same problems with the aspire rear swap. Once you move the engine forward and take weight out of the back the rear tires just want to lock up with hard braking and turning. Out of curiosity are you considering using Aspire drums and spindles to get around the need to redrill the wheel pattern?
          • #95
            Laguna is going to make you wish you had a B6t. Lol. Are you taking the Vette too? Definitely a HP track. The big bore cars are going to pass you on the uphill and hold you up through the corkscrew. It'll still be a blast. If we badge our cars as Mazda 121 then maybe we can do that yearly Mazda event.
            What do you mean by "dual rear springs"?
            I use drilled Festiva drums on my cars, but this one has an Aspire rear setup. I haven't totally decided what I'm going to do in the rear. I want to raise the beam mounting point so I can lower the center of gravity and still be in the "sweet spot" of the beam travel. I might make my own beam, but it's really hard to beat the stock beam.
            • #96
              Just the mighty 50hp Festiva. I'm just excited to track a properly setup Festiva. I got the 120 treadwear nankangs. I didn't even have matching tires on the last build.
              Doing a track day with you would be awesome. I'll do my best to get a decent build going to make it worth going.
              14 C7 Z51
              • #97
                I pulled this for the donor engine to build for Casper. It's a BP4W. I'll use the BP05 for initial chassis testing and then swap it for this engine with a few minor modifications.
                • #98
                  Oh Charlie, I didn't see you asked about the dual rear springs on Scrappy. There's a thread on here about it from a while back, but the long and short of it is the FMS rears didn't have enough rate to keep me from bottoming out with any weight in the car, and the kyb valving on the slow circuit was crap, so I created a spring to sit inside the FMS rears that have next to no preload at full droop to keep noise down. It allowed me to carry stuff in the rear and keep things fairly comfortable. I used it to get 2 full dress b6ts half a trans and other parts from Canada, with Caety, and I rubbed once the entire trip home. The rear was tucked once loaded.
                  • #99
                    Oh, nice!
                    • So I am sitting dtown Des Moines, IA. Up walks a guy and comments on my Festiva. Turns out it is hamburgerler!!!! He is wanting to build another one.....
                      Sent from my SM-G920R4 using Tapatalk
                      • Cool, bout time he showed up here again.
                        • Not build one. I wanna get my 88 carby up and running. So weird met a festiva.com guy last night. Sweet ride tho
                          Proud owner of Casper
                          • Good to hear from you but what brings you back to Iowa.
                            • Oh work. Quit my job in az and the winds blew me back to ia. I'm in Des Moines now and really enjoy it
                              • Glad to have ya back, D.M. is a good town with plenty to offer, hope you find something for work that you like.
