Ømëga build thread
    I'm in class taking my master cert for auto trans I've got some time to kill lol. Jackstands are fine until you get distracted with other projects. I've bought like 7 different cars since I tore mine down to do a bunch of major upgrades so all my time and money are going to those projects instead.
    Better Than Nothing Racing
    Way too many cars
    :woc:
      oh wow 😍 these are beautiful expensive 2000+200 shipping but these are the first wheels that are in my size and pattern that I really love
      Sent from my XT1585 using Tapatalk
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      Aspire brake swapped
      stripped and sold due to rust
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
        Originally posted by Festiver View Post
        oh wow �� these are beautiful expensive 2000+200 shipping but these are the first wheels that are in my size and pattern that I really love
        Those do look nice but $2200 is slightly out of my budget lol... You can buy like 4 more Festivas for that.
          Just put a v8 in and call it a day
            Lmao true if I get a career good enough I'll drop the cash then run economist tires lol expensive wheels cheap tires good tires though
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
              The biggest problem with the G series tranny isn't in the tranny, it's what's connected to the tranny. The same problems are seen in the Miata trans when high TQ and High RPM are extracted from a BP engine. This is due to the inherent harmonic problems that the BP suffers from. I've seen plenty of guys put an aluminum under drive pully, a lightened flywheel and stiff motor mounts and go to the track and have problems with broken oil pumps, broken crankshafts and shattered diffs and gearsets. Add TQ to this mess and your asking for trouble.
              The fix to these issues was not cryo treating the gears, it was a propper damper pulley and flywheel and drive line mounts that absorb the shock load rather than transferring it the the brittle bits of steel that fail when rattled. Third gear doesn't loose teeth because the shafts are flexing, it looses teeth because of harmonics and it's typically the gear that high TQ cars start to hook up and transfer immediate shock loads to the driveline.
              The OE engineers are very aware of these harmonics and that is why they build engines with harmonic dampeners, dual mass flywheels, fluid filled mounts and rubber couplers in the drive line. So many "tuners" ignore the single most destructive force in an internal combustion engine and they toss this engineering in the trash bin and blame failures on the TQ. Meanwhile, they use impact guns to break free fasteners. Ironic.
                I really didn't think the harmonics were transferred to the trans but that makes sense ok I'll notch the passenger frame rail and go for the best dampener I can find ati seems to be a favored term I'll look around though also I'm not going for any extremes with ømëga I do love bp torque and with some light turbocharging I imagine it'll be a great all arounder if the mpg isnt good I'll ditch the turbo
                Festiver
                93 L find/5 speed
                BP/g15mr swapped
                89 festie
                rustful
                93 festie
                advanced suspension
                kai/skeeter camber
                b3t/g15mr
                  The harmonics are often amplified by driveline components if precaution is not taken. A good friend of mine has been doing sonic failure anylisis on industrial machinery since the 1980s. He taught me a lot about the effects of harmonics, and how they can be managed. His trade detects failure points in machines that must run constantly without failure for years at a time and he monitors these machines. There are billions of dollars at stake in his trade, but the same thoery has held true for the race cars I've built and his advice has helped me build reliable endourance race cars. When your pushing the limits for 20+ hours at a time, harmonics are serious business.
                  The BP engine has 2 fatal flaws that generate destructive harmonics. 1. It's rod ratio is foolish for a sport derived engine without a balance shaft. 2: The crankshaft pitch is not helpful at the frequencies that we know to be harmful to hardened steel parts from 2-4" diameter (yeah, gears and oil pumps.... Hmmm).
                  Furthermore, the pulses from the power strokes of the engine create their own harmonics, which can fatigue parts. The tourque pulses also act to break tire traction (think of it like your engine is an impact gun that's working to break your tires free like a tight bolt, the pulses break the bolt free, not the torque.)
                  On paper, a B6 engine should be able to hook up about 15 percent more TQ than the BP simply because of it’s more favorable rod ratio. Rod ratio has a direct effect on the tractability of a vehicles power delivery. There's more to tuning race cars than adding displacement and turning up the boost. Unfortunately, these engineering theories rarely make it into "tuning literature" and are never mentioned in marketing.
                  • #24
                    Hmm that really changes the way I think on power delivery especially the impact metaphor makes a lot of sense though I'm not sure what directly cause harmonics I'll definitely have to do my research
                    Festiver
                    93 L find/5 speed
                    BP/g15mr swapped
                    89 festie
                    rustful
                    93 festie
                    advanced suspension
                    kai/skeeter camber
                    b3t/g15mr
                    • #25
                      So to revive this lil prebuild planning out thread I crunched some numbers and I'm looking at about 2400 in suspension and wheels 😂 that's really not bad considering I'm replacing everything from the towers down with all brand new parts but still a good chunk of change
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                      • #26
                        ENOUGH with all the plans time for some progress! Past 2 nights I've completely stripped the interior from dash back the car didn't hold onto the rust free expectations I has a bunch of small rot spots but none structural it's good enough I will do as much as I can myself and have a pro do what I don't feel comfortable with
                        The plastics are in amazing shape as this car will be a 2 seater I will sell these
                        The rear bench had a perfect frame I will try to sell this as it's just too clean to trash
                        I had 2 heart attacks tonight as I unknowingly was within 3" to a wasp (don't do wasps) twice once was my face looking under the car
                        I'll begin rust repair tomorrow starting off on the easiest and moving to more difficult
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                        • #27
                          Rust repair is going well besides a cut off wheel blew up cutting my leg a bit all is good though I made another dash wrench Because I lost my first one
                          To make this dash wrench it's very simple but perfect for the job
                          1x 1/4" extension 1-2" length
                          1x abrasive cutter (cutoff wheel)
                          1x welder
                          1x grinder (pedestal grinder works best
                          Just cut the tip off the extension
                          Weld the tip 90° on the side of the extension
                          Grind the shaft of the extension at a steep angle to clear the windshield
                          Done you can use another 1/4 extension to give a longer handle for leverage
                          Festiver
                          93 L find/5 speed
                          BP/g15mr swapped
                          89 festie
                          rustful
                          93 festie
                          advanced suspension
                          kai/skeeter camber
                          b3t/g15mr
                          • #28
                            I grinded it a bit more to clear when the bolt is out
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                            • #29
                              Also little touch grind off the snap on logo so no one knows you hacked a snap on 😂
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
                              • #30
                                Talkin to myself a lil but that's ok so interior is gutted steering column firewall insulation and gas tubes are all that remains also roof and rear wiring the black is all rust repair next gonna pull the steering system to clean up then gas tank and all the lines hoes for the gas and brake systems
                                Festiver
                                93 L find/5 speed
                                BP/g15mr swapped
                                89 festie
                                rustful
                                93 festie
                                advanced suspension
                                kai/skeeter camber
                                b3t/g15mr
