JDMSTIVA V2 Build Thread
Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Looks great! What kind of paint was this??! It took me like 10 cans to paint 6 rims years ago, lol.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 06-13-2017, 01:40 PM.
Will Samet
How to find me:
Yup! At least the Faces of 4 14" wheels.Originally posted by ryanprins13 View PostOne can did 4 rims?
Although I would recommend using the Wheel Coating basecoat. This stuff is more like a coating than solid color paint, so bare aluminum imperfections show up pretty easy. I bought 2 cans just in case, so I will be redoing these at some point using the base coat and my 2nd can.Will Samet
How to find me:
Thank you!Originally posted by Festivaranch View PostThey look awesome dudeWill Samet
How to find me:
The next main project I completed for the JDMSTIVA V2 were coilovers!
It was once a pipe dream for me, but after scoring a few lucky deals, I was finally able to complete a set!
I based this off of Mike Mounlio's Ultimate Street Suspension Guide and Advncedynmix (Charlie's) Advanced Suspension Mods Thread.
It started with the front set. I found a used set from another member here for around $200, that had already been drilled and slotted to fit a Festiva.
After looking into it, they ended up being a set made by Charlie himslef, so the quality of the work was above and beyond!
The spring rates were way to high, so I got to work ordering the right parts.
I went with 120 LB 12" Springs on the front and 105 LB 10" springs in the rear.
Everything else more or less follows the threads I mentioned above; Please give them a read, they are both great write-ups!
My Then-Girlfriend, now Fiancee, got me the rear struts for my birthday, and the build started. Here is all the parts spread out on the table:
I went to clean up the used fronts. I used brake-clean, a wire wheel on a drill, and got some silver paint to protect the bottoms.
And here they are, my completed coilovers, waiting to be Installed!
Will Samet
How to find me:
No, just threw them on to hold the springs down till they are ready for installation. I will be using the upside down perch like in Mikes Guide when the time comes!Originally posted by william View PostYou using those top hats on the rear?
Never see anyone use those looks like they would wiggle around a bunch with that big of a hole.Will Samet
How to find me:
I went with the right-side-up KYB lower perch, because the skinnier part holds the springs in place.Originally posted by w4rkry View PostNo, just threw them on to hold the springs down till they are ready for installation. I will be using the upside down perch like in Mikes Guide when the time comes!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I think we are talking about the same thing Tom hahaOriginally posted by TominMO View PostI went with the right-side-up KYB lower perch, because the skinnier part holds the springs in place.Will Samet
How to find me:
Looking good Will! Do you have some bump stops for the rear?~Nate
Current cars:
FOTY 2008 winner!
Thanks!Originally posted by skeeters_keeper View PostLooking good Will! Do you have some bump stops for the rear?
I do now, I put them on last week!
Will Samet
How to find me:
