JDMSTIVA V2 Build Thread
Will Samet
How to find me:
Feel free to PM me anytime!
Instagram/Twitter: @WILLSAMET
Looks great! What kind of paint was this??! It took me like 10 cans to paint 6 rims years ago, lol.
Sent from my SM-G920W8 using TapatalkLast edited by ryanprins13; 06-13-2017, 01:40 PM.
Will Samet
How to find me:
Originally posted by ryanprins13 View PostOne can did 4 rims?
Although I would recommend using the Wheel Coating basecoat. This stuff is more like a coating than solid color paint, so bare aluminum imperfections show up pretty easy. I bought 2 cans just in case, so I will be redoing these at some point using the base coat and my 2nd can.Will Samet
How to find me:
Originally posted by Festivaranch View PostThey look awesome dudeWill Samet
How to find me:
The next main project I completed for the JDMSTIVA V2 were coilovers!
It was once a pipe dream for me, but after scoring a few lucky deals, I was finally able to complete a set!
I based this off of Mike Mounlio's Ultimate Street Suspension Guide and Advncedynmix (Charlie's) Advanced Suspension Mods Thread.
It started with the front set. I found a used set from another member here for around $200, that had already been drilled and slotted to fit a Festiva.
After looking into it, they ended up being a set made by Charlie himslef, so the quality of the work was above and beyond!
The spring rates were way to high, so I got to work ordering the right parts.
I went with 120 LB 12" Springs on the front and 105 LB 10" springs in the rear.
Everything else more or less follows the threads I mentioned above; Please give them a read, they are both great write-ups!
My Then-Girlfriend, now Fiancee, got me the rear struts for my birthday, and the build started. Here is all the parts spread out on the table:
I went to clean up the used fronts. I used brake-clean, a wire wheel on a drill, and got some silver paint to protect the bottoms.
And here they are, my completed coilovers, waiting to be Installed!
Will Samet
How to find me:
Originally posted by william View PostYou using those top hats on the rear?
Never see anyone use those looks like they would wiggle around a bunch with that big of a hole.Will Samet
How to find me:
Originally posted by w4rkry View PostNo, just threw them on to hold the springs down till they are ready for installation. I will be using the upside down perch like in Mikes Guide when the time comes!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by TominMO View PostI went with the right-side-up KYB lower perch, because the skinnier part holds the springs in place.Will Samet
How to find me:
Looking good Will! Do you have some bump stops for the rear?~Nate
Current cars:
FOTY 2008 winner!
Originally posted by skeeters_keeper View PostLooking good Will! Do you have some bump stops for the rear?
I do now, I put them on last week!
Will Samet
How to find me:
