The bucket, progress thread
  • #31
    If you did a 1mm over bore (common, lots of pistons available)
    With 1mm stroke you'd end up at 1650cc so plus 54cc over stock
    CURRENT. Past
    88 festiva L. 89 xr4ti
    14 foST. 89 xr4ti
    82 F100. 97 silverado
    82 GS1000. 06 h3
    82 GS750. 79 ta 6.6
    74 TC185. 89 turbo katana 600
    69 T500. 80 gs1000
    15 sonic 82 cr480r
    • #32
      Honestly these cars are new to me and have about served their purpose with me it's just they keep crawling out of the woodwork. MY friend has one of those cars sitting in his backyard he'd take 50.00 for it etc.And I keep buying them, distracting me from my real projects. But the formula I always use for displacement on a 4 cyl is borexborexstroke times .0031416 you will have to use common sense at the end to know the displacement, you are going to end up with a weird number, but if you use the first 4 numbers ignoring the zeros you have displacement.These cars have just been a sideline distraction to me I don't even know the bore and stroke on them just my first one was so much fun as a beater and others kept falling into my lap I'm still playimg with them. To any one interested , I am ready to jump out of this 5 cars to liquidate,some parts.some drivers. Going to keep one because they are fun and cheap.,QUOTE=Thebrandonbeezy;757015]If you did a 1mm over bore (common, lots of pistons available)
      With 1mm stroke you'd end up at 1650cc so plus 54cc over stock[/QUOTE]
      • #33
        What rings are you using.
        Better Than Nothing Racing
        Way too many cars
        :woc:
        • #34
          Stock, they show no wear.
          If i had to over bore I'd run wiseco
          CURRENT. Past
          14 foST. 89 xr4ti
          82 GS1000. 06 h3
          82 GS750. 79 ta 6.6
          69 T500. 80 gs1000
          15 sonic 82 cr480r
          • #35
            I wouldn't reuse rings. Get a new set of factory rings.
            Way too many cars
            :woc:
            • #36
              wheels fit rather well. itll need some massaging, but shouldnt need to cut the fenders. shes a little tight on the inside but it should be good
              20180712_200905 by Brandon Hobock, on Flickr
              20180712_200938 by Brandon Hobock, on Flickr
              20180712_200915 by Brandon Hobock, on Flickr
              20180712_200815 by Brandon Hobock, on Flickr
              20180712_200722 by Brandon Hobock, on Flickr
              rear
              20180712_200612 by Brandon Hobock, on Flickr
              front
              20180712_200551 by Brandon Hobock, on Flickr
              20180712_200153 by Brandon Hobock, on Flickr
              ive reused rings quite a few times with no issues.
              got some pto scheduled for tomorrow, gonna head over to the machine shop with the head and some cash
              CURRENT. Past
              14 foST. 89 xr4ti
              82 GS1000. 06 h3
              82 GS750. 79 ta 6.6
              69 T500. 80 gs1000
              15 sonic 82 cr480r
              • #37
                Just to confirm, miata arp studs are the preferred wheel studs?
                CURRENT. Past
                14 foST. 89 xr4ti
                82 GS1000. 06 h3
                82 GS750. 79 ta 6.6
                69 T500. 80 gs1000
                15 sonic 82 cr480r
                • #38
                  Last time I looked at press in ARP studs, Vette ones were cheapest, but that may have changed
                  Will Samet
                  How to find me:
                  Feel free to PM me anytime!
                  Instagram/Twitter: @WILLSAMET
                  • #39
                    Ok, is the passenger side axle nut reverse thread?
                    My mac impact has no effect in either direction and its 1260 ftlbs breakaway.
                    Dont wanna use a breaker bar in the wrong direction
                    CURRENT. Past
                    14 foST. 89 xr4ti
                    82 GS1000. 06 h3
                    82 GS750. 79 ta 6.6
                    69 T500. 80 gs1000
                    15 sonic 82 cr480r
                    • #40
                      Yes the passenger side is reverse L/H thread.
                      Impact clockwise to get it off.
                      • #41
                        Thanks man, yeah my impact wasn't budging in either way unfortunately. Hope it comes off with the breaker bar
                        CURRENT. Past
                        14 foST. 89 xr4ti
                        82 GS1000. 06 h3
                        82 GS750. 79 ta 6.6
                        69 T500. 80 gs1000
                        15 sonic 82 cr480r
                        • #42
                          The REAR spindle nut is LH thread. Both front axle nuts are normal RH thread.
                          Way too many cars
                          :woc:
                          • #43
                            Thanks guys, i got it. Lifted the car off the ground and broke the breaker bar.. but in the end i won LOL
                            CURRENT. Past
                            14 foST. 89 xr4ti
                            82 GS1000. 06 h3
                            82 GS750. 79 ta 6.6
                            69 T500. 80 gs1000
                            15 sonic 82 cr480r
                            • #44
                              Picked up my junk from the machine shop, .030 should bump the compression nicely.
                              2018-08-25_11-10-55 by Brandon Hobock, on Flickr
                              CURRENT. Past
                              14 foST. 89 xr4ti
                              82 GS1000. 06 h3
                              82 GS750. 79 ta 6.6
                              69 T500. 80 gs1000
                              15 sonic 82 cr480r
                              • #45
                                Pulled vacuum on all the ports they were all good so no valve job needed
                                CURRENT. Past
                                14 foST. 89 xr4ti
                                82 GS1000. 06 h3
                                82 GS750. 79 ta 6.6
                                69 T500. 80 gs1000
                                15 sonic 82 cr480r
