Does anybody know if you can posi-trac or lock axles on a Festiva to get both wheels pulling? Air locker maybe? (not wanting phantom grip)
Posi-traction, Festiva
http://www.reverbnation.com/main/sea...t_songs/266647Tags: None
I have seen these things for sale called "phantom grip" that fit into the diff unit, but trans has to come apart and some machining has to be done. I have no experience with these-other than seeing them for sale. Maybe someone on the site knows more?186,000 miles per second is not just a good idea, it's the law
1990 yellow L+ (l8ly)
1990 yellow L+ (sunryz)
1992 aqua L (agua)
1993 blue L (aurora)
Spider gears could be welded up. But you wouldn't be able to turn without breaking something.-Greg
Redneck Engineer
FOTY - '09
Mazda (actually the performance division, MazdaSpeed) makes a limited slip differential for the G series transmission (F series too), but it's hard to get. Quaife makes one for the G series also. It runs around $1000 + though.
Properly set up, the Phantom Grip is pretty good.
Welded spider gears will work, but on each turn, the inside tire will spin (it would eat tires real fast) and there is the chance of breakage every time you do anything but go straight. It would be like an old school RWD spool.Last edited by JPT; 01-28-2010, 06:10 PM.Festiva: Because even my dog can build a Honda.
^ Thanks! $700 isnt to bad. What about airlockers? Any made that would fit Festiva's? A friend of mine and I both had 1980 Broncos. He had airlockers on his.
Wow! Was all I could say when I drove his bronco. What a difference. All 4 wheels pullin' in the mud and turned off, drove normal on roads and turns.
Both front wheels pullin' on a festy would be sweet.Dan
Why you don't want the phantom grip ?¿?Originally posted by drddan View Post(not wanting phantom grip)
Well, i've heard good and bad about the phantom grip, sounds like its a "rig" and not strong for serious racing, as a spool or true locker. I wanted to know if a locker was available for the Festiva.Originally posted by Maxtiva View PostWhy you don't want the phantom grip ?¿?
I 've seen ARB airlockers for Suzuki samurai, sidekick,vitara ...and honda and toyota. Can one of these be adapted to a Festiva?Last edited by drddan; 02-10-2010, 01:57 PM.Dan
All the civic drivers I know that have used phantom grip have broken their diffs so that's the reason why I don't want one.Current cars:
Quaife it and forget it.Autocratic...
Buy these dope wheelshttp://forums.vwvortex.com/zerothread?id=4193133
theres a phantom grip in jasons, track b6t festiva i bought from him, now i dont have a really sticky tire to do a full launch on yet but with the tires he has on the car which where auto x tires, it sure doesnt seem any different with the phantom grip. im thinkging of getting another mfactory and kia trans for jasons car,
