Originally posted by Damkid
P5 kills
I am not trying to be rude, but true bragging rights come from track slips. That V6tiva has not yet run 12 seconds. It should be able to do it, but it hasn't yet done it. Therefore I would feel more safe doing a BP or BPT swap into a Festiva. Good luck with the turbo swap.Last edited by timmay89; 02-23-2011, 10:28 PM.
That's why I don't brag about my track times cause I know it's not the fastest festiva, maybe the fastest N/A, but not the overall fastest
I'm really surprised Chris. Can you slap some really wide slicks on it just for the track? Is it just a traction issue?youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Traction isn't too bad, it's the clutch that is my weak point, I'll be ordering a new clutch before spring so with that alone I'll hit 13's garenteed
Yup probe trans too, a guy from work has a nitrous setup he's going to sell me so who knows what times I'll pull lol
So what's with the clutch slipping? You just put everything together. The trans is designed for the power it's receiving from the engine. The load on the clutch was decreased by several hundred pounds when it moved from from the 2500 lb probe? To the 1700 pound festy. Was the clutch new? Sure you've been running it hard but still you just got it all together. Just curious.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
I had to re-use the clutch I got from the probe parts car I bought, but due to time and money constraints I never got the flywheel resurfaced either so the clutch has been weak as hell since day one, when I get a new clutch I will get the flywheel resurfaced this time so I don't have clutch issues this year
Hey Chris, when you went to the track, did you drive the car on to the scales?
...and I know I must have asked before, but how much extra weight did the 'ZE add?Festiva: Because even my dog can build a Honda.
I would think it would be quite a bit heavier. Two more cylinders, another head with two more cams...Originally posted by 91blufestiva View Post^ I don't know exact numbers, but I've read that the ZE isn't much heavier than a BPFestiva: Because even my dog can build a Honda.
There was one time I went across a scale (at a scrapyard) and it said 2260lbs with me in it, I weigh approx 150lbs and if I remember right I had half tank of gas, the scales looked pretty old so I dunno how accurate they were though
And I moved my spare KL by hand around my garage and did the same with my B6T, the KL didn't feel much different in weight
