raced my friends wrx
  • #31
    ID say an hx35 or 40. Is the exhaust turbine side split where the flange attaches to the manifold?
    1991 blue L, 5 speed.
    1988 red L-plus-all stock.
    • #32
      Yes the flange ia split. What is it off?
      • #33
        Originally posted by bobbyspider View Post
        These are the numbers on the turbo:
        Series num: to4b49, 465640
        Num piece g.f.: j0156f
        Num piece client: 4797662
        It also says garrett on the plate and after lookin closer I now think its a t4 flange on one side.
        Any idea what this thing is?
        T04B is the housing and trim.
        1989 Carby L: Stock. Slow.
        1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
        2016 Focus ST: daily driven go-kart
        • #34
          Would this do me any good on a bp or it too big? Any idea what it off of?
          • #35
            b housings aren't the most efficient, on smaller motors they tend to be sluggish (i.e. poor driveability). I would find a T3 with a .63 A/R back side and a super 60 compressor (think TurboCoupe Tbird), personally.
            • #36
              ^listen to the man. Most likely off a diesel truck and capable of ALOT more than you want. Full spool by about 4500 lolz I really have no clue bu it would be up there!
              • #37
                Nos ='s cheating? Since when?? That's a-kin to having an Evo wth all wheel drive ad a turbo going p against a stock fox 5.0. You gots to even the odds somehow.
                • #38
                  i plan on running an HX40 on my spitfire... not sure if im gonna run a BP or an FE3N yet though. bullseye performance makes all kinds of hot sides down to .42 ar which should spool as fast as the 16G im currently running(around 3500-3800rpm)
                  the radiator hose was just fine all the way up to 18psi(highest i boosted regularly) very little,if any, expansion under boost.
                  No nos its considered cheating in a race around here. Gotta pop the hood and trunk before the race to set that there is no bottle or hookup
                  challenge accepted... i can hide almost anything almost anywhere ... and its not a bad idea to use spray to spool a big turbo.
                  I know its a piece of crap but im still faster...and its 100% legal!!!!!
                  • #39
                    fastivaB6TG25MR Great minds think a-like.
