Has anyone hit 11 seconds with a bp turbo festiva yet? just wondering
Bp turbo times?
Bp turbo times?
There's a Festiva that was built by the member (celicaGT4) that made 304whp, apparently it runs 11's but no one has ever seen proof, that's the only one I know of
alright just wondering cause Im rebuilding my bp cause I crashed into a tree and thought might as well rebuild the engine so I went with forged cp pistons, eagle rods, acl bearings, arp head and main cap bolts, racing timing belt and cometic head gasket, gasket kit from domestic gasket for the rest and got the head redone. I wanted to boost it after the rebuild it is done and was wondering if its hard to get to 11's because of traction? or some other reason? thanks
Bp turbo times?
If 11's were easy to get in a festiva, don't you think there'd be more 11 sec times on the fastest festiva list?
Bp turbo times?
The diff's are the weak points, get an mfactory LSD and the trans will take a lot of abuse
Bp turbo times?
^^the phantom slip I used helped my diff pin go through the tranny, I'll never use another one again
Lol that must of sucked but for u guy that are looking to upgrade your LSD here a wright up on g series transmission Using Mazda speed LSD http://www.mazdas247.com/forum/showt...-5th-Gear-Swap
