Overkill did great out there this weekend! I ran pretty decent times. I can pick up a lot of time in places that i know i missed. I didnt push hard enough to get the rear lose but maybe 3 corners. I had 1 corner where i had to use the power to pull out of it. I was ready for it and trying to do it and it did it!!! It was the 1st corner. I stayed on the gas until corner entry. Once i started to turn i then let off the gas or a split second. Rear stepped out and i gave it to her. The car pivoted and pulled right through the turn with nearly no lose in speed. It felt great. Sadly i didnt push that hard any other real time. other times it started to do that but held together.
The car held together as well. Next race is this coming weekend. I will do a bolt check and get ready to go again.
I need to really work on my left foot braking. I was not doing that this time out. I was moving my right foot back and forth. Im sure left foot would help me gain a second or two. Also i forgot to fill up. As i would enter each turn my gas would slosh around and cut out. Then i had to pedal it to get back in power. Im sure that was cutting a second off my times as well. I think next weekend willl be much better. I will work on my left foot braking this week and try it out come sunday. I also forgot to install my boost line to the water meth. So i had no spray!
I beat a few seasoned drivers in nice well prepped cars. I can feel the power of this setup. The car will be a top contender once i learn how to drive it better.
. Again off the line i did the biggest 1st gear burnout i could until the triple cones hit 2nd and took off. I still yet backed off early. I still let out early and braked harder then i needed to. The car hooked up at all times! the rear was planted the front grabbed the power went to the ground she went straight with very little torque steer. I was smooth on and off the gas and brake. I was still a bit jerky with the wheel tho. It all cam together to run a less then 2 seconds off the leader and about 1 second off the next guy in line. I had her moving. I do think i could have improved even more givin another lap but thats the name of the game.
