removing factory stickers/stripes?
  • removing factory stickers/stripes?
    Just wondering if anyone has any hints regarding how to easily remove the stickers/stripes?
    I've used the hair dryer with a straight edge and some come off fine but with the other stripes only the top layer comes off. Anything that would make this easier?
    Plain old mineral spirits or paint thinner on a soft towel with elbow grease will do it. Not the good expensive stuff...but the cheap stuff will work better because it will not go after the paint as easily...biggest trick...don't rub to hard to generate any heat.
    Joe Lutz
    The SKATE ..... 1992L 5spd
      ^^ Yep
      I used WD-40 when all I had left was the sticky left .
      HD2500 Duramax Chevy
      Z28 LS1 power 500 +
        a rubber wheel decal remover on a die grinder air tool will take off the decal with the adhesive...that way you don't have to use mineral spirits/wd-40
