I'm adding an air conditioning system to my '91
Festiva w/Kia B6ME engine. I found '92 at the local
U Pull It salvage yard and took everything A/C
related except the reciever/dryer (going for new one),
the compressor and the compressor mounting bracket. The system is the factory installed unit with
a thermo expansion valve (TVX). The Kia B6ME engine I'm running has a crank pulley for a ribbed
A/C belt which I would imagine could be swapped for a single groove if need be.
As for the compressor, the one on the car at U Pull It
looks nasty and I don't imagine it's good so I looked online for a new unit and found none. I am not wanting to buy a rebuilt because of the high rate of failure I have seen. So my question is does anyone know of a new compressor that will work in place of the "correct" unit? I'm looking for plug and play.
In other words I don't want to heavily modify my compressor mounts. I can get the Festiva mount at U Pull it and somewhere in my shop lies the compressor mount that came on the B6ME engine.
The compressor should be compatible with the stock Festiva compressor lines. Any advice or will I be stuck with trying the nasty used one at the yard or buying a crappy, expensive rebuild?
