Steering Wheel Replacement/Fix
  • Steering Wheel Replacement/Fix
    Hello!
    The steering wheel on my 88 has gotten all rubbery, and is slowly falling apart. I’ve tried some aftermarket covers, but they tend to slip when I turn, which I obviously don’t want.
    Im assuming finding an original tan wheel in good shape is a long shot, so has anyone found a solution that works well for this?
    -John
    1990 Festiva - Throttle Body/Manual Transmission
    Bought in 2003 with 65k, now 219k
    1988 Festiva - Carb/Manual Transmission
    Bought in 2015 with 150k
    Have you serched the Internet? Auto parts suppliers may have steering wheels. In the meantime you could always try wrapping the wheel with tape, or if you want to get fancy and spend a few dollars, bicycle handlebar tape.
      Better yet... have you searched this forum for free Festiva parts.
      I have a sandlewood one but it's on my yellow 90 so you can't have that one. But I do have a nice gray one that you can have if you pay the shipping.
        I’ve been looking online, but haven’t found much. I’m may just have to do a wrap.
        That’s great of you to offer! The interior is in pretty good shape, so I’d like to find something tan or brown that matches if I can. Where did you get your sandalwood one? That sounds pretty sweet.
          Sandalwood is the name of that tan interior color. (It came on my 1990 L-Plus the yellow one that is my avatar picture)
            Oh okay. Good to know!
              I do have a couple of free saldalwood interior parts show in this thread: https://fordfestiva.com/forums/forum...or-pay-to-ship
              The rear compartment cover is in beautiful condition but the seat belt cover (which is not in an 8 is not complete.
                I'm about 90% sure 88/89 tan is different than 90+ Sandlewood. The dish of the wheel changed between 88/89 and 90+ models as well.
                You can mount an aftermarket wheel using an adapter for a NA Miata.
                '88 L- B6d-Sidedraft Dellorto Carbs-G-Series-Advanced Suspension
                  The Tans are indeed different.
                  Also worth noting that the LX wheels are a different material, they are soft foam while other trims are hard plastic.
                  Will Samet
                  How to find me:
                  Feel free to PM me anytime!
                  Instagram/Twitter: @WILLSAMET
                    Thanks for getting me straight. In the future I will refer to this link in the forum which seems to have all the correct information about Festiva Color Schemes.
                    Am I reading the chart correctly? Did Sandalwood show up in 1990 and then was dropped in 1991 but came back in 1992-1993?
                    https://www.fordfestiva.com/aboutfor...lortrimsel.htm
                      That's a Typo actually, 90+ is all Sandalwood
                      Will Samet
                      How to find me:
                        I see other incorrect information in that chart too. It says the Pop Yellow and Surf Blue colors were only available in the L models but I currently own a 1990 L-Plus Pop Yellow and a 1990 L-Plus Surf Blue was my first Festiva.
                        Do you know of there is a correct color charts anywhere on the internet?
                          The color charts are correct, you just have to ignore the trim limitations. Those limitations actually were in a bunch of original documentation from Ford, but they changed it at some point and didn't update everything.
                          Will Samet
                          How to find me:
                            Have you found an aftermarket wheel that works well? I’ve never used one on a Festiva, but I’ve tried on other vehicles, and it isn’t always great.
                              I have a Nardi but other brands work as well. Just make sure the adapter hub matches the steering wheel bolt pattern.
