MFM Window Wrap
  • MFM Window Wrap
    How well dose it kill road noise?
    If it works good it would be a tempting alternative to dynamat/b-quiet exct.
    How quiet is the intereior with it applied?
    My fest is sooo loud on gravel roads. My ears start to ring
    89SX funtop! Fully loaded!
    RIP 90LX
    I'll bet!
    I remember when my rear bearings were going.
    My ears were ringing when I got to work and that was on a relatively well maintained 4 lane highway.
    Remember someone doing this, but don't recall a report on the final results!
      I have done it before with my # 2 Festiva L and it help a lot and kill the most noises. here the pictures of past with my green festiva...
      Warning: using fiberglass mat stuffing up in hollow space can make you so inchy and lung hazard! always wear safety and be sure cover up them!
      There some advantage and disvantage with fiberglass, the good it kill a lot nosies but bad it will give your festiva cancer of rust when water is leaked inside of car. So be sure no leaking water inside of your car from window!
        hey festivaGTX! where did you get the stuff you used and what is the product name? It sounds better than the window wrap... this stuff is atchuley sold as sound insulation! is it self adhesive?
        RIP 90LX
          I brought it from Home Depot store and they are great stuff to use in many ways. It's not self adhesive, but you can buy the spray cans adhesive (seen in one pic) it's powerful can!
          I am going check up what name of company and i think i still have one left roll somewhere and it was 2 year ago!
            Farmtek sells that stuff under the brandname TekFoil
            From hobby gardens to commercial farms, shop farm supplies, greenhouses, fabric and metal buildings. Same-day shipping on in-stock items.
            Jim DeAngelis
            kittens give Morbo gas!!
              i used it and the expanding foam with exceptional results.
                what parts of the car did you use the expanding foam on? and where did you get the window wrap?
                RIP 90LX
                  Anyone try the window wrap flex? its 70mils thick compared to 25 for the regular window wrap.
                  And they specifically mention that it cuts noise
                  RIP 90LX
                    i used the foam on the rear strut towers and between body pannels ant the support structure. the wrap covered as much flat surface i could reach from the rear seat hump back. i think i'll use the "flex" when i do my next festy.
                    oh and i also used 3/8" carpet foam to give the stock carpet some added padding.
