I looked at FMS and do not see bearing shims.Anyone know where to get the sets to rebuild the front ? 8)
Front hub bearing shims
Call FMS
They do not have their entire inventory on their web site.
Or can source shims from Mazda ask for 323 shims.
Why do you need them, often the existing shims will work with the new bearings and races!'93 Blue 5spd 230K(down for clutch and overall maintanence)
Originally posted by smcawcI haven't taken my spare set apart,yet.I just wanted to be prepared.Thought they'd be bad.???
Originally posted by FB712000-2002 Kia Rio uses the same spacers in the front hubs.'93 Blue 5spd 230K(down for clutch and overall maintanence)
The bearings themselves do not vary enough to worry about. The variance that the shims are for is for the machining of the hub. If you use the old shims with the same hub they came from and replace the bearing, the odds are very good that everything will be fine.
