I looked at FMS and do not see bearing shims.Anyone know where to get the sets to rebuild the front ? 8)
Front hub bearing shims
Call FMS
They do not have their entire inventory on their web site.
Or can source shims from Mazda ask for 323 shims.
Why do you need them, often the existing shims will work with the new bearings and races!'93 Blue 5spd 230K(down for clutch and overall maintanence)
The bearing spacers do not go bad as they are not wear items. The various sizes of spacers are out there to compensate for slight variations in bearings. As PU stated, there is a good chance that the ones you have will work fine.Originally posted by smcawcI haven't taken my spare set apart,yet.I just wanted to be prepared.Thought they'd be bad.???
Ah, another golden nugget of info!Originally posted by FB712000-2002 Kia Rio uses the same spacers in the front hubs.'93 Blue 5spd 230K(down for clutch and overall maintanence)
The bearings themselves do not vary enough to worry about. The variance that the shims are for is for the machining of the hub. If you use the old shims with the same hub they came from and replace the bearing, the odds are very good that everything will be fine.
