N E one know what this turbo is for ????
  • N E one know what this turbo is for ????
    I just picked this up from a friend.It is SMALL. Any ideas ???
    can you get some pics of the compressor? it usually has some id tag. who's it made by?
      I would say it's the B6T turbo. T19 if I'm right.
      Is that a Festiva that just passed me?!?!?!
        i saw a 4 cyl. mustang, mid to late '80's model that had one like that i think. it's been 15 or 20 years ago. hard to remember.
        1960 willys pickup
        1967 jeep cj5
        1988 festiva
        1989 festiva
        1990 festiva for parts
        1991 s-10
        "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
          Chevy Sprint, maybe?
          Jim DeAngelis
          kittens give Morbo gas!!
            i think the 3 cly only came with the turbo not the 4 cyl
            Mike, AKA the sasquatch
              ok, wasn't sure. Maybe a small commercial diesel engine?
              Jim DeAngelis
                Didn't the B6T come with a VJ14 turbo???
                  This is what i read off of it...GARRETT ....ATD p/n:466672-2...Model:TBO3....Cust p/n:1367867....S/N:pj1034a...
                  Below is what I found on my little searching.....
                  1991-1993 TB03 Garrett used on intercooled 16V 2.2 (Turbo III)
                  The TBO3 is part of the T3 family of turbochargers from Garrett. In this application the main differences are the larger compressor wheel and housing for better airflow (Turbo III engines are rated at 224 hp), and the exhaust housing which has a more "universal" flange pattern unlike the Turbo I, II and IV engines. Ford SVO Mustangs use a similar housing as well as one or two other auto manufactures. There is a wider variety of exhaust housing ratios available for this turbo because of this. It will NOT bolt to a regular SOHC exhaust manifold.
                  You could in theory have the slightly larger wheel and compressor housing swapped onto a TO4 turbocharger, but I'd imagine there would be some wastegate can issues along with the fact these turbos are relatively scarce. (from Mopar anyway) It would be cheaper to have a S60 or S70 wheel installed on your TO4 and it would flow more air as well.
                  TBO3 specs:
                  Compressor housing A/R .52
                  Exhaust housing A/R .48
                  Compressor inducer 45 mm
                  Compressor exducer 60 mm
                  Exhaust turbine diameter 48 mm
                    Late eighties volvo 740 Check it out
                      the 63 confuses me , though.?? :?:
                        The newer turbo dodges???
                          You're right, my bad :wink:
