This is what i read off of it...GARRETT ....ATD p/n:466672-2...Model:TBO3....Cust p/n:1367867....S/N:pj1034a...
Below is what I found on my little searching.....
1991-1993 TB03 Garrett used on intercooled 16V 2.2 (Turbo III)
The TBO3 is part of the T3 family of turbochargers from Garrett. In this application the main differences are the larger compressor wheel and housing for better airflow (Turbo III engines are rated at 224 hp), and the exhaust housing which has a more "universal" flange pattern unlike the Turbo I, II and IV engines. Ford SVO Mustangs use a similar housing as well as one or two other auto manufactures. There is a wider variety of exhaust housing ratios available for this turbo because of this. It will NOT bolt to a regular SOHC exhaust manifold.
You could in theory have the slightly larger wheel and compressor housing swapped onto a TO4 turbocharger, but I'd imagine there would be some wastegate can issues along with the fact these turbos are relatively scarce. (from Mopar anyway) It would be cheaper to have a S60 or S70 wheel installed on your TO4 and it would flow more air as well.
TBO3 specs:
Compressor housing A/R .52
Exhaust housing A/R .48
Compressor inducer 45 mm
Compressor exducer 60 mm
Exhaust turbine diameter 48 mm
