Shifting question.
  • #31
    i wanna see a video of some reversies in a festiva =)
    lightweight turbo festiva eventually... till then RALLY 323 FWD 1.8 turbo w/DMS suspension.
    www.youtube.com/watch?v=R8RQWpCQTEM
    http://good-times.webshots.com/album/563922096TbQTzO
    • #32
      Originally posted by scitzz1
      I haven't always had a tach, but I have always driven this way. I learned back when I was 19, and the clutch was going on a company car I drove, the owner taught me. I still use a clutch when I am delivering, I am in too much of a hurry to play with it then. For normal driving though, I am clutch less except to start. Twice, I have had to drive with no clutch to start, come to a stoplight, turn off engine, put in 1st, turn ign switch, rabbit hop to get rolling, and away I go! If you are not on a steep hill, do it in 2nd, and you don't really hop at all in a festy!
      that sounds like a recipe to burn up your starter motor! i would only do that if there was no other choice (i'm sure thats why you were doing it, but figured it should be mentioned).
      i shift w/o the clutch on occasion, but most of the time i use the clutch... i have extra clutches (ok, so i have extra tranys too, but..) and i'd rather replace a clutch than a trany JIC i would screw up too bad.
      one time i had been practicing going clutchless for a while, then i had to accelerate a bit quickly thru 4th, and w/o thinking about it just jambed it into 5th.. ground a little but i got lucky it was close to the right rpm! After that i only go clutch less on ocasion to make sure i can still do it .
      ~Nate
      Current cars:
      FOTY 2008 winner!
      • #33
        i cant do that with mine i have the after market kia clutch so its alittle ticker then my stock one
        • #34
          once I get her put back together this sprin I'll be sure to take some
          92 GL - parts car
          97 aspire - parts car
          87 323 DX - daily driver
