updated with pictures... on first post...
16's?
For height, yes they'll fit. Width, they should but it'll be a tight fit. You'll need the perfect offset (try various spacers) and you'll probably need to do something with the fenders.
If you can make them work, it'll look good!Last edited by JPT; 08-11-2008, 03:47 PM.Festiva: Because even my dog can build a Honda.
yeah they fit perfect on the back but the front will be a whole different story... i might have to raise it up a bit and also if i get them he said he would give me his gray MOMO steering wheel i have been after... but so what all would have to be done if i got these...?
1989
Ford Festiva L
Automatic
can someone tell me the exact things i have to do to get these to fit... or show me a link to a page that tells me i can't find in search but he had a little bad luck and 2 tires popped so i'm getting them momo steering wheel and a exhaust... it's stinks tho cause the tires are going to cost me like 100 a piece to replace..
1989
Ford Festiva L
Automatic
well i want to be able to drive and i would get something else but there is no way i'm going to find another deal this good anytime soon... they fit in the back but i havn't done the front aspire swap so i don't know about the front at all... well if there is anyone that lives near Evansville in with the front part of the aspire swap done maybe they could let me see on there car..
1989
Ford Festiva L
Automatic
Unless the offset on the rim is some ridiculous number, I think they'll fit. 205/40-16 is shorter than 195/50-15 and 185/60-14 (and 175/70-13). These sizes have been used on many Festivas. The only thing with the tires you have is that 205mm is just over 8 inches wide. That is about the limit for width. If you don't lower it (much) they should work.
195/55-14 is just about the same height and just a touch narrower and this size fits fine (relatively speaking).Festiva: Because even my dog can build a Honda.
If they were designed to fit a Honda (and if the manufacturer used the factory offset) the offset is +45mm.Festiva: Because even my dog can build a Honda.
you find the offset by placing a strait edge on the back side of the wheel, on the lip where the tire mounts, and measure from that plane to the mounting surface of the wheel.Neil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
91 L B6-me f25mr-soon to be ???
86 b2000- pisses of HOA-sold
1997 k1500 suburban- kid hauler/GAS hog
try them on to find out if they'll fit
