There are a couple lying around in the local junkyard and I feel like there must be something from the car that could help me put a B6T in my Festiva or could sell to someone else. What parts from these cars are desirable?
What should I grab off an Escort GT?
engine tranny, intermidiate shaft, harness ecu, shifter maybe, basically anything that could be used to swap the motor into a festyis not sposed ta do that...
05 subaru legacy gt
1991 nissan nx2000(almost awesome as a festiva, my first failed mtx)
1988(?) festiva LX 5spd (rescued from crusher,aspire swap done, working on turbocharging the 1.3...)
the intermediate shaft will not work you don't need the harness to swap in the engine, just a couple connectors, although if it's a standard, grab the ECU, tranny, axlesOriginally posted by solatare View Postengine tranny, intermidiate shaft, harness ecu, shifter maybe, basically anything that could be used to swap the motor into a festy
If 96 or earlier....2 or 3 door model....both the driver and passenger side automatic seat belt tracks and motorm. They self destruct....nearly impossible to locate and they sell on e-bay for a small fortune.Joe Lutz
The SKATE ..... 1992L 5spd
front calipers and rotors will work when transfered over the aspire brake swap. You will have to run 14" wheels minimum. The brake booster should work because the protege one does.---------------------------------------------------
