what to do and what not to
Seafoam?
- Unknown
- Quentin Crisp
- Bumper Sticker
Heres a couple videos that Packrat427 made. Good stuff.
How to , where to put it in at.
Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
Driving to clear it out afterwards.
Again a simple search and just a little reading netted these results.:thumbleft:Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
No problem. Kinda wanted to read up on it myself.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
My 2 cents: Sea Foam does alot. It will break up carbon when sucked in a vacuum line. Don't put it the oil, I collapsed a lifter in my 300 cid Ford, tryin' it.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
I've put it my oil before without issue. Not very hard to repump the lifter or replace if that happens....but I doubt it was the seafoam that did it. Just a coincidence that it happened at that time."FLTG4LIFE" @FINALLEVEL , "PBH"
Oh yeah, don't suck it in the vac line if you have a cat converter. It will send the carbon deposits downstream. I did this to my F150, and stunk up the entire trailer park.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
Originally posted by BigElCat View PostOh yeah, don't suck it in the vac line if you have a cat converter. It will send the carbon deposits downstream. I did this to my F150, and stunk up the entire trailer park.
You can use it on Cars, trucks, snowblowers, lawnmowers, inboards, outboards, motorcycles, snowmobiles, tractors and chainsaws.
ALL modern cars have catalytic converters. If you were supposed to avoid using in in vehicles with cats, it would advise you ON the can.
You CAN use it in:
Your Crankcase in the oil
The gas tank
The injection/carburation system via vacuum hoses90 Festiva with Brand new B3, 5spd
92 B6 Festiva, 5spd
has anybody used Motorvac? i used it at school on my town car.
it really smoothed out my idle and i gained 19 horsepower. (i did a before and after on the schools dyno) the only problem is that is done with a machine so you would have to find a shop that has it.
The main advantage Sea Foam has over a 'motorvac' job is cost. A local mechanic wanted $180.00 to perform a motorvac. There's hardly any labor involved in hooking up. I guess they have to recoup the cost of the machine.
I just remembered that my collapsed lifter came from using a quart of kerosene in the oil, not from Sea Foam. I used Sea Foam in the gas tank and in the vac line. This was 10 years ago. I remember the huge cloud of smoke, and thinking it was good thing that I had removed the cat converter.
I may just try Sea Foam on Festus, now that I realize its 'cat safe'.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
I have a question. Would you use this as an oil additive or put it in and run for a short time just before you changed your oil?Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Monsoon,
Good question and the best I can find for you is this:
Makes a certain amount of sense!
But, this isn't the offical Seafoam site.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Great info! Thank you very much Pu241! :thumbleft:Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
