I've never owned an auto Festy before, and I have a few questions.
Is it normal for them to shift hard from 1st to 2nd gear? Mine will slam into gear if I'm giving the car a lot of gas. 3rd is pretty smooth.
Also, what is the lifespan of the drivetrain? Can I expect 200,000+ out of my automatic?
Do the higher RPMs cause excessive engine wear? I can't imagine cruising at 4000 rpm does the bearings/water pump/alternator any good.
Regards,
Tim
Regards,
Tim
Poverty produces creativity
