wierd suspension noises
  • wierd suspension noises
    OK,
    I got alignment done on the Festiva and I dont know what they losened or tightened but when I drive and turn right there's a crackling noise (like if you squat down and your knee pops) on the right front of the suspension. Same thing when I turn to the left.
    Has anyone experienced a problem like this? Now keep in mind, I went underneath and tightened every single nut n bolt visible to man! All were fine not lose at all. Brackets all there, bushings replaced new, new shocks, new wheels and tires, newly rebuilt Aspire hubs all around with new pads and shoes along with the new sway bar. I am getting pissed off so if anyone has an ideas I will try them. I must be missing something but what????
    Thnx
    Ski
    1986 Ferrari Testarossa
    2002 BMW 745i
    2002 BMW 325i
    1989 BP'd Festi :p
    Drive axles??
    99 Dodge Caravan SE
    95 Taurus SHO auto 265hp
    94 F150 351W auto (for sale)
    95 Honda 1500 Goldwing SE
    95 Iszuzu Trooper LS
      Redone...new boots....
      Ski
      2002 BMW 745i
      2002 BMW 325i
      1989 BP'd Festi :p
        Ball joints? Mine made that sort of noise just before the drivers side broke on me.
        - Unknown
        - Quentin Crisp
        - Bumper Sticker
          did they replace the ball joint pinch bolts? i've been having a lot of trouble lately with the pinch bolts not holding the ball joint in place and when accelerating it made a "clunk" noise, i beleive i finally have this problem solved
            Hmmm...I replaced the whole arm (brand new)including pinch bolts...hmmmmm...I wonder if I should change them again? Good spot, even though I know they are tight. Ball joints are brand new too...I just had them put in cause of the Aspire brake swap.
            Ski
            2002 BMW 745i
            2002 BMW 325i
            1989 BP'd Festi :p
              Check and make sure everything is tight and right, I had a spring not seated right and everytime I turned it made a funny popping noise.
                I will do that....good point
                Ski
                2002 BMW 745i
                2002 BMW 325i
                1989 BP'd Festi :p
                  I had a noise coming from the strut mount when I turned. I guess the bearing in it wasn't very free or just worn out or something
                    When mine were replaced they installed a standard sized bolt which left a slight amount of play, even though the bolt was tight it still wouldn't hold the ball joint, if you decide to replace them again, use a 10mm hardened bolt and be and make sure when the bolt is installed the ball joint doesn't ride on the threads to wear the bolt down (i had that problem as well)
                      That's a great possibility! I would presume in an alignment they would probably tighten the strut nut?! Huh? When turning the spring would skip the spring seat.....
                      Ski
                      2002 BMW 745i
                      2002 BMW 325i
                      1989 BP'd Festi :p
                        Yup...I checked the bolts...they are new originals....ones that actually are made to hold the ball joint.
                        Ski
                        2002 BMW 745i
                        2002 BMW 325i
                        1989 BP'd Festi :p
                          Thats true, I'd check it out!
                            Figure anything out?
                              Well I took the top shock mounts apart...one of the plastic "bearings" was kinda screwed up so I got a newer one at the junk yard. Just put it in so I doono yet it that fixed the problem. Drove few miles since and it seems its not creeping when I make a sharp turn into the driveway, sooooo hopefully that was it!
                              Thnx for asking
                              Ski
                              2002 BMW 745i
                              2002 BMW 325i
                              1989 BP'd Festi :p
