just curious about others experience with the festiva. i have a 1989 lx auto trans. i just turned 282k. i just had to(today) replace the ORIGINAL starter. the alternator was replaced@250k the engine still runs fairly strong, i dont really use any oil except through leaks, about a 1/2 quart every 3k miles. do you think i will get to 300k? how many others have and if i decide to change the engine out how much will it cost??? thanks and happy motoring fellow festiva lovers.
how many miles on your festy??
282k? Just getting broken in! 300k won't be any problem, and with regular maintenance, should easliy see 400k, maybe even 500k. We have members here that have gone that far.Jim DeAngelis
kittens give Morbo gas!!
Wecome to the forums, i think 282 k is awsome. 1/2 quart aint bad, could be vavle cover gasket or oil pan gasket. I am pretty sre you will make it way pass 300 k with the regular maintainence.
The easiest thing to do with the engine would be to swap a b6 ( early 323) into it. Its basicly a bolt in and you get about 20 more hp.My festiva has only 87,xxx miles on it so i can hope that it will last as long as yours.
BTW post pictures man, I'm sure vwe would all love to see it.
176,000 and I am not sure , but I think the rings just started to seat this week .
It does not use a drop in 3,000 miles .------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Well the stock engine had 173K on it and didn't leak or burn a drop of oil. New engine has about 1200 on it, but the stock trans is strong, its just broken in."If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
Mine has 137,210.6 miles on it. Everything is pretty much original on the car and it doesn't skip a beat.
Judging by some of the other Festivas' mileages, mine isn't even broken in yet!
-TimWhite '89L auto - Sold!
Silver '06 Rav4, 95k!
132,000 showing,but when I got the car speedometer cable was broken so I don't know real mileage!!!Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
