CB antenna
  • CB antenna
    would it be possible to make a cb antenna out of a festy radio whip? im not sure of the requirements of a cb antenna so i have no clue.
    it'll do the 1/8 in 13.7, spin tires, and make all my drunk buddies giggle.
    "I like a Festiva because there's less car to get in the way of the driving experience"
    I would have to say it would take a lot. I use to be a CB'er and your antenna would have to match down to your radio by using a SWR meter. Your antenna and radio have to be within 1.l to 1.5 match for your radio to transmit or receive. Get a regular cb antenna magnetic mount to where you can put it on top of your car or remove it when you want. Like i said, an SWR meter will tell your match. You can usually bring the match down with correct antenna by lower top of antenna. I use to run whips, cans, magnetic mounts and double antenna's mounted on mirrors. Or get a walkie talkie with extended antenna and you can receive up to about mile depending on topographical terrain.
    93 Festiva (Little Red Truck)
    01 F-150 (Big Red Truck)
      kinda...
      You could but it wouldn't get good reception. It is too short, and the wrong basic design. You could, however, replace the festy antenna with a short range cb antenna and use the festy mount.
      Just an idea.
      Slainte!
      -Mike
      91 Festiva L 1.3l 5spd
        i figured it would be a long-shot. just thought id ask.
