might be adding to my ford collection
  • might be adding to my ford collection
    i might possibly get the money for this... doesnt look too bad(needs a car wash tho) but i wonder why it wont start... thats got me puzzled
    Originally posted by JoDan View Post
    HTML Code:
    http://desmoines.craigslist.org/cto/1029458321.html
    Your link doesn't work.
    Chuck
    91 GL -Ol' Rusty
    93 GL - Lil Red
    91 L - Tweetystiva
      does that help?
        that looks like quick little car.. i don't know if these are interference engines or not.. if not, then they may have messed up the timing.. especially if the belt broke.
        also, do these have a crankshaft position sensor? If so, then it may be bad.
        -Aspire brake swap COMPLETE!
          i would think if the belt broke and its an interference engine it would not have compression at all. bent valve, busted piston, etc.
            so do you think that if i bought it i could get the timing fixed and get that sucker running?
              i just looked it up and it is NOT an interference engine...
              i'd say its either timing or ignition coil or something relatively easy as it was running before or at least they said it was...
                a friend of mine had a 626 and the timing belt broke on him, he replaced it and could not get it to run again, i went and looked at it, and it had 3 timing marks on each cam shaft and by watching the lifters i realized the belt was installed by the wrong timing marks, therefore it wouldn't run, but it did when i was done with it
                so this maybe something of whats going on with that probe, and if thats the case then it wouldn't be hard to fix and get running
                  I say get it and if you can't get it running you could part it and get your money back easy
                  Facebook Me!
                    well... i called the guy and its supposed to be sold friday...:crybaby:... so the search is on again...
                      any probe is a pain to work on anyways...
                        ehh, early Probes aren't that bad...
                        also, it's a 2.2L (Mazda F2T) not 2.3L (Ford Lima)
                        the F2T is a single cam, 12 valve. And yes, it has three timing marks on the cam, and I think two on the crank...
                        Jim DeAngelis
                        kittens give Morbo gas!!
