Clock blank removal
  • Clock blank removal
    How does one remove the clock blank without damaging it or anything else.
    Thanks
    make sure your fingers are real dry (grippy), or put on some rupper gloves and pull on it....mine popped loose doing it that way.
      pry it off with your fingers from the top if I remember correctly, the only thing really holding it on is weak metal spring clips.
      Current cars:
        yep, just some metal clips holding it on. pry it from the top and it should pop off.
        89 L, hopefully returning from the dead soon with a little more power... :twisted:
        http://www.fordfestiva.com/forums/sh...77-my-89-build
          A very thin flathead screwdriver at the top. Or as mentioned above, just grab and pull from the top.
          Simon - pimptiva.com
