i'm not sure why but my 89 festiva lx kinda chugs at low speeds, or any speed that isn't accelerating. if you are speeding up its smooth, but just "cruising" at 45 mph its jerky. i do have a "service engine" light lit up on the dash. any thoughts?
chug-a-lug
may be time for a minor tune up. when did you do plugs, air filter, etc...? also, run a bit of seafoam through the engine to clean things up... just some thoughts..
-Aspire brake swap COMPLETE!
Check timing. Make sure you disconnect and plug the vacuum lines to the distributor or you will be 13+ degrees off. I bought a festiva from a guy who timed it wrong and it was giving me the same issue. Fixed the timing and she has tons more power.The Festiva Store
Another possibility is the fuel filter. However, I am not sure if it would be smooth acceleration if it were.http://www.cardomain.com/id/hawkdoc60
01 Chevy Impala 9C1 police package "Unnamed yet". 154K
88 LX 5 speed "Silver PHOENIX" Currently being rebuilt inside and out. 400K
88 L 4 speed "Cherry Bomb" saved from the car crusher just in time. 186K
06 Ford F-150 Pickup Replacement for my 2001 Impala Cop Car that lunched its engine.
tell me more about this, i'm not all that up on the carbed cars, its my first.Originally posted by nonamekid View PostCheck timing. Make sure you disconnect and plug the vacuum lines to the distributor or you will be 13+ degrees off. I bought a festiva from a guy who timed it wrong and it was giving me the same issue. Fixed the timing and she has tons more power.
