I have a dent on my front left fender. i found a festiva in a junkyard with a clean looking fender. how do they come off?
How to change fender?
two or three 10mm bolts in the door well, maybe two on the bottom of the fender behind the wheel. 3-4 on top of the fender, (under the hood). and i think some screws that run up through the bumper into the fender. might be some small screws near the back or the wheel well. i think thats about it. should only need a phillips and a 10mm socket.
cubstiva1 has got it.
Take some PB Blaster for the screws in the wheel well!
And a little on the bolts wouldn't hurt either!
Also, if the dent isn't bad save that fender.'93 Blue 5spd 230K(down for clutch and overall maintanence)
Yea it sucks. Last owner did. I would never abuse my festy.
