anyone know where i can purchase the gasket under the distributor cap for 90-93 festiva?
gasket
www.rockauto.com Fel Pro Part number 35608 will work for all 88 - 93 Festivas.
Chances are none of the local parts stores will have it. Try having them look it up with a 91-96 Escort or 94 - 97 Aspire. I found a few parts that way even though they should be cross referenced to work with Festivas.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by MONSOON View Postwww.rockauto.com Fel Pro Part number 35608 will work for all 88 - 93 Festivas.
Hey..it looks like the napa guy found it. Monsoon just to confirm, in the Napa parts directory it's called a distributor cap mounting o-ring. Doing this over the phone, so I want to make sure that sounds right. The napa guy thought this o ring sat at the base of the distributor itself and not between the cap and the distrib. I told him no it should sit at the base of the cap.Last edited by xlence; 08-06-2009, 04:13 PM.
HEY! I dont always jump on people about their posts. Besides this 1 didnt look familiar.
I have found the same thing with some of the relays as well. The headlight relay from 91 - 96 Escorts is the same thing, you just have to remove a little tab on the Escort one for it to fit.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by MONSOON View PostHEY! I dont always jump on people about their posts. Besides this 1 didnt look familiar.
The plugs and pins line up perfectly then? Do you still have to order left and right sides respectively?
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Didnt know there was more than 1 headlamp relay.When I got mine and put it in they both started working. With the exception of that one tab(youll know it when you see it) you have to break off its a perfect match.Last edited by MONSOON; 08-06-2009, 04:44 PM.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Originally posted by MONSOON View PostDidnt know there was more than 1 headlamp relay.When I got mine and put it in they both started working. With the exception of that one tab(youll know it when you see it) you have to break off its a perfect match.
92 GL - parts car
According to the Haynes manual theres only 1 and 1 for the Parking lamps also. That may be the one youre thinking of.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
I have found the same thing with some of the relays as well. The headlight relay from 91 - 96 Escorts is the same thing, you just have to remove a little tab on the Escort one for it to fit.So o-ring sounds correct?
Regarless, thanks again for the info.
